I was riding home tonight going about 42mph in 3rd and the bike actress as if it ran out of fuel for a sec gas gauge shows alittle over half rang says over 100miles. It cut out and came right back no check engine light yet. Do the 2011 dyna throw a check engine light for a bad miss fire or loss of fuel pressure? It's only done it one time in the 60 miles I have owned the bike but something isn't right I don't thank. It has big radius exhuast screaming egal big sucker and a screaming egal super tuner pro other then that it's stock but when your bike cuts out and a car is on your *** it will wake you right up any input would be great thanks
Hopefully you also checked the ground cable connection. Sometimes this is overlooked. Same with fuse and relay tabs that get corroded over time.
You could have a pinhole leak in the fuel tank line or a clogged fuel filter.
Where is the ground cable on the frame? I checked relays and fuses. Wouldn't a clogged fuel filter or pin hole in the line Cuz the iusse all the time or throw a code for being lean?
The ground cable is on top of the starter motor.
You won't get a code with a dirty filter or hole in the line, or if it's running lean.
