Agree with most of the above, but have a point to add. My FXD was killing me over the bridge approach slabs on my back road "jaunts". A friend and I like to go pretty fast; not race fast like I did when young, mountain roads and blue ridge parkway in Va. But, my Dyna would hammer on the front end as it hit some of the "bumps" on the bridges. I actually got off to look at some of the bad ones....about 1-1 1/2 inch steps in the pavement. So, off came the front shocks. This was last year after I got it with about 10k on the odo. Oil was pretty heavy....fairly clean. I did a rough measure of visco using an eye dropper and time to empty. Seemed to be about 20wt. I put back mostly 10wt with just a taste of 5wt. Much better. Next change will be 7wt. As above, the springs hold the weight, and the damper with oil does just that....damps. These mundane shocks are not adjustable for either compression or rebound as are the racing shocks. BUT, they will work pretty well with proper hydraulic fluid. Agree with add of better valving, since the holes in the damper tubes do not compensate, but are constant size. They work OK, but could be improved. Mine is fine for a street bike now. And remember Russian Adm Gorshkov......better is the enemy of good enough.
Keep in mind, oil doesn't hold the bike up, the springs do. The weight of the oil determines the overall springiness feel of the forks. 20w would make for a harsh ride better suited to a racing bike on smooth roads. 10w oil is a good overall choice for softer feel on bumps but still enough to slow the rate of compression and may prevent bottoming out on pot holes and high bumps. Also helps on those washboard intersections. 20w may actually let the front wheel come off the pavement, something you don't want.
Keep in mind fork oil should be changed about every 2 years so just replacing it with stock oil will improve the handling. Try some 10w and see what you think. It's easy and cheap to experiment with different weights from 7.5 to 15 w.
Some real good info here.
Keep it simplea nd start with 10w as mentioned above, best compromise for country and freeway riding.
I have a 2013 switchback I bought used 8months ago, had 30,000 on the clock, and yes the front was a bit bouncy.
I dumped the fork oil and put in 10w....it did improve the overall ride of the bike.
You would have to consult the Factory Service manual for your year and model but generally there is a drain screw at the bottom of the fork and a cap at the top. Loosen the cap, remove the drain screw to get the old oil out. Put the drain screw back in and fill, through the cap at the top, with recommended quantity of oil.
It would be a small phillips head screw on the back side of the folk lowers just above the axle nut. if you don't have that screw then you have to pull the wheel and axle and it will be a allen head cap screw (metric) directly through the bottom of the forks. You have to have the Factory Service manual for your year and model. Otherwise you are guessing and probably guess wrong. Look online for free PDF otherwise about $60 from the dealer for a printed copy.
I'm running Racetech springs and Gold Valve emulators in my Switchy. Great improvement in ride quality and handling. I'm running 10wt Belray fork oil...no complaints.,,,,,,,,,,,,,,,,,
Did a very similar mod on my 2014 BO with same result. The only difference is, I used Richor Intiminator emulators instead of the Gold Valves. Richor recommended that with their product, in my 49mm tubes, that I use 5 wt oil which I did. The legendary Breakout "braking nose dive" is gone, handling is responsive AND, commonly encountered road bumps are all but erased. "The best of all worlds".
A notable difference between the Richors and the Gold Valves is, that you don't modify your damper tubes when installing the Richors. They're a drop in component, set up for you at the factory.
With fixed aperture technology, (damper tubes), all you're gonna do is trade off riding smoothness for handling by dicking with oil weights. Override the damper tubes with a valved system, and the game changes and oil becomes more than a trade-off choice.
I am 6'2" @ 280. I had a bottoming out issue with excessive sag (talking about the bike here ) and tried several different pre-loads and oil weights before finally giving up on the OEM springs and installed Progressive springs with 20W Bel-Ray High Performance fork oil. The front feels a little stiff on the road but it is steady in hard curves and the brake dive has been greatly reduced...and no more bottoming out so far...
