6 gal. tank on FXD Superglide
Old Dec 5, 2016 | 09:29 AM
mpescatori's Avatar
mpescatori
Default 6 gal. tank on FXD Superglide
Hello all, I have thoughts at times and this one I simply cannot shrug off.
My 1995 Superglide has a 4.2 gal tank (16 liters) with a center-fill cap.
I would like to know if there's a tank out there which will hold anything between 5.5 and 6.5 gals which is more or less a direct bolt-on replacement.
I aim to go long range (solo) touring and I can only get 240km (150 miles) between stops; anything beyond that means switching into reserve...
I have found "6 gal Fat Bob" tanks with are described as "direct bolt on for fat Boy etc." so I am confused...
Are Dynas and Softails compatible to that extent? Or is there a mistype or misunderstanding ?
Furthermore, as these 6 gal tanks are all of the "two halves bolted together" type, when I lean the bike over to fill up, and fuel level reaches the lh fuel cap/gauge...
...any issue with seepage or is the twist cap actually safe?
Thank you
Old Dec 5, 2016 | 04:54 PM
NORTY FLATZ's Avatar
NORTY FLATZ
My 1995 Superglide has a 4.2 gal tank (16 liters) with a center-fill cap. a tank out there which will hold anything between 5.5 and 6.5 gals which is more or less a direct bolt-on replacement.
The factory stock HD tank capacity for the '95 FXD is 5 gal.
"Reserve" holds almost a gallon, so you've got another 30 miles of range before sweating it.
Unfortunately, you are carb'd. It's great for performance, but range suffers (as you've discovered.)
Your choices are~
1. Just ride your bike and get fuel more often, or
2. Sell your bike and go "fuelie."
3. Modify your existing FXD to fuelie
4. 3.1415926...
Old Dec 5, 2016 | 05:02 PM
Yamaharley's Avatar
Yamaharley
Dynas have a square backbone. Makes finding tanks difficult. A wideglide tank would be what you are looking for with the speedo centered and the gas cap and gauge on the sides of the top. If I'm not mistaken it's only a slight increase in capacity though. My tank had a dent so I've been searching for a low rider style one. Low riders had the speedo and tach on the tank.
Old Dec 6, 2016 | 07:37 AM
mpescatori's Avatar
mpescatori
Smile
Thank you.
THIS is what I'm talking about. I am partial to bar-mounted instruments so a tank bib is the way to go.
Fat Bob Softail 6 gal. tank
So either it's for a Fat Bob... or it's for a Softail... or it's compatible to both so it should fit the square tube of a Superglide...
I emailed them an enquiry on compatibility but haven't received a reply yet.
Old Dec 6, 2016 | 08:46 AM
multihdrdr's Avatar
multihdrdr
Harley re-uses "Labels" and that can cause misinterpretations depending on your knowledge base...
They are not referring to the Dyna FXDF "Fat Bob" (introduced in 2008). Think of a Split Fat Bob tank as a Style of tank.
FWIW, Harley also made an older FXEF "Fat Bob" introduced in 1979 (i think) and it also used Split "Fat Bob" tanks.
You can probably see how issues occur
Old Dec 6, 2016 | 11:25 AM
Kid Red's Avatar
Kid Red
Yep, it can get confusing but Multihdrdr is putting you on the right path. There are Peanut tanks, Tear Drop, Mustang, Alien Head, Stretched, etc... all styles of tanks along with Fat Bob. I wish I could point you to a bigger tank that'd fit your bike but at least the type of tank is clear as mud now.
Old Dec 6, 2016 | 11:35 AM
nevil's Avatar
nevil
Seems like a lot of effort and expense just to gain maybe another 30 miles in range, but if it's something that means that much maybe someone here will come up with a solution.
Now, there's a little bit of jealousy here. I only wish my aging body could go 150 miles without needing to be pried out of the seat.
Old Dec 6, 2016 | 12:08 PM
mpescatori's Avatar
mpescatori
"Think of a Split Fat Bob tank as a Style of tank."
Unfortunately you are right.
The vendor finally replied and explained that "Fat Bob" is a style of (extra large) tank made specifically for Fat Boys and other Softail-based models.
Maybe a Road King tank might do the job ? I'm really keen on this thing... we're talking an extra 60-70 miles on a tankful.
In some places, it really means "getting there" vs. having to strap a jerrycan...
burntcookie10
Oct 19, 2016 01:56 PM
Hood Bush.
Sep 21, 2016 09:56 PM
mpescatori
May 29, 2016 03:35 AM
markrinker
May 26, 2015 06:51 PM
trepanner2
General Topics/Tech Tips
Feb 16, 2012 11:18 PM
