Dyna jack arrived!
Old Jan 7, 2017 | 01:47 PM
TinCupChalice's Avatar
TinCupChalice
Originally Posted by Gearhead88
Thank's for the pictures , The position of the two channels appear to be an ideal width for a dyna.
The J&S does fit the Dyna frame nicely; with the Dyna having basically only one way to position the J&S about the only concern I'd have is if I were to be stripping down the rolling chassis to the frame and the engine/transmission/primary in the frame. As you pull the weight from the bike I'd suspect she'd get nose heavy on the lift due to the front lift arm being directly between the cylinders. If I start stripping her down that far, there will be some straps on her then
Old Jan 7, 2017 | 10:23 PM
stonei3's Avatar
stonei3
Nice choice! I'm a big fan of the jack as well.
Old Jan 8, 2017 | 07:33 AM
grumpy56's Avatar
grumpy56
Have had mine for several years and works as advertised. Only pain is making sure it is positioned just right or you can "jack things up" if it is not correct. Causes me to crawl around on the floor a few times to ensure it is in the right place. How far do the bars stick out on the primary side when you guys use yours? I'm always afraid of contacting the primary cover and lifting that (not a good thing) rather than the frame.
Old Jan 8, 2017 | 07:38 AM
lionsm13's Avatar
lionsm13
Good point..
Have one myself and agree with the positioning of the jack.
Takes a bit but after that, steady as she goes.
Old Jan 8, 2017 | 08:00 AM
TinCupChalice
On a Dyna when you've positioned the J&S so the rear lift arm is behind the frame protector and pan you'll have plenty of clearance between the lift arms and the primary; I don't see how the primary and lift arm could contact each other...
SluggoMagoo
Sep 27, 2018 03:37 AM
04fxdwgi
Jun 27, 2017 05:11 AM
Danzyg1
Oct 13, 2013 11:13 AM
jb1023
Dec 1, 2009 09:49 PM
wmo777
Jan 21, 2009 05:39 PM
