Progressive suspension
Old Mar 5, 2017 | 11:43 AM
MRFREEZE57's Avatar
MRFREEZE57
I installed the progressive 444's on my LR, 12.5" while not like a thousand dollar set, a great improvement over stock, went 1/2 longer than stock, no more muffler scraping.
Old Mar 5, 2017 | 01:10 PM
Ghost_13's Avatar
Ghost_13
Originally Posted by dpoll995
it sits a little higher now. im gonna test it out and adjust the height if needed.
This is not the reason to set sag
Ghost
Old Mar 8, 2017 | 11:43 AM
Twospot's Avatar
Twospot
Ok so the stock Low Rider shock is 12"? I've been trying to confirm this since I am thinking about this upgrade but not looking to change height. Just ride quality. Thought about these and the progressive fork cartridge kit.
Old Mar 8, 2017 | 03:14 PM
Jay Guild's Avatar
Jay Guild
Correct. I put the 12.5" 444s on the back last summer and they ride great. Looking at doing the monotubes this spring. I've heard the combination improves things greatly.
Old Mar 8, 2017 | 05:24 PM
DonN's Avatar
DonN
I have progressive 970s on the rear. I have the ricor intimidators and traxxion straight rate springs on the front. The ricor/traxxion is the way to go up front and not too spendy.
Old Mar 8, 2017 | 06:45 PM
retxpres's Avatar
retxpres
Originally Posted by Jay Guild
11" on the rear ends up being a bit stiff no matter the spring rate due to the limitation of travel once compressed with weight. That and you end up having to lower the front as well to maintain your rake and replacing the kickstand. I've used them and not only is it stiff but you bottom out easily and you lose lean for corners. Maybe look in to monotubes for the front.
I have never bottomed out. Just a hard ride.
Old Mar 9, 2017 | 08:55 AM
Jay Guild's Avatar
Jay Guild
Did you lower the front?
Old Mar 9, 2017 | 06:32 PM
retxpres's Avatar
retxpres
No...
Old Mar 10, 2017 | 09:07 AM
Jay Guild's Avatar
Jay Guild
No...
I did and I usually bottom out from the front diving on compression. Probably didn't have much to do with the rear suspension.
newtothe48
Jun 4, 2016 02:14 PM
Bluraven
Jun 19, 2013 03:12 PM
Mozvader
May 7, 2013 06:56 AM
Raven Rider
Sep 16, 2010 08:46 PM
trackadaptor
Jan 17, 2008 02:36 AM
