Cooling a WG
Old Mar 25, 2017 | 06:41 PM
  #31
fxdli's Avatar
fxdli
I don't wish to get in to a pi$$ing contest as what is the best an or the coolest. I do know when I look down at the temp an its running 20-30 deg cooler. "You can't argue fact" Called my Bud asked what he paid for the unit $42 or 45.
Old Mar 25, 2017 | 06:52 PM
  #32
Ghost_13's Avatar
Ghost_13
Attachment 503825
No pissing..., just wanted see the data / approach
Oil filter relo kits are typically a few hundred bucks..., please post the source..., as I'm sure several would be interested if they could be bought for under $50 bucks
Appreciate your participation
Ghost
Old Mar 25, 2017 | 07:09 PM
  #33
fxdli's Avatar
fxdli
He says Oil filter relocator Kit on Ebay by Summit Performance $46.97
Old Mar 26, 2017 | 05:29 AM
  #34
Warp Factor's Avatar
Warp Factor
Originally Posted by Ghost_13
After reading your post...., I was going to blow it off...., chalk it up to ignorance / or as you being one of the many bullshitters occupying this forum...
Yeah..., I was
Aside
I don't mind disagreeing comments..., hell..., I don't even mind being called a stupid M' Fer for the way I'm approaching this
But if you do..., least have your **** together..., and be able to back up your mouth
And/ or.., be prepared to offer up a better thought / idea / approach
Just spouting **** - serves no one..., nor any purpose
Ghost
LOL, sounds like you are the one who is spouting.
Old Mar 26, 2017 | 08:02 AM
  #35
fxdli's Avatar
fxdli
As Mark Twain said " Better to remain silent and be thought a fool then to speek/type and remove all doubt" Again you can't argue fact!
Old Mar 26, 2017 | 08:08 AM
  #36
cggorman's Avatar
cggorman
This is a fact-finding topic about the cooling effectiveness of the Wimmer tubes. I thought it was going well.
Old Mar 26, 2017 | 08:54 AM
  #37
W.Glide's Avatar
W.Glide
It was. It just took a slight left turn at the moment. Keep up the good work guys!
Old Mar 26, 2017 | 09:50 AM
  #38
Ghost_13's Avatar
Ghost_13
You were offered an opportunity to back up your assertion - that these cylinders have inadequate cooling surface area
You could have even compared this system..., to other(s) systems of your choosing
And this response I quoted..., is the best you can do
Ghost
Old Mar 26, 2017 | 09:54 AM
  #39
Ghost_13's Avatar
Ghost_13
And it'll continue - once them last four connections get in (one on back order)
In the meantime - we've identified a cheaper alternative to the expensive oil filter relo kit
I'm open to sharing / discussing whatever is out there - that might offer a less expensive (albeit has to be viable) alternative
***** expensive as it is
Ghost
Old Mar 26, 2017 | 02:44 PM
  #40
Ghost_13's Avatar
Ghost_13
Damn finally..., after a few beers..., my head's cleared up
Let's go on another little "fact finding" (fishing ) trip
You've said that a couple of times now - let's just see
This unit was given to me from a friend (FREE).
It also runs 10-15% cooler now.
As you say - however
And TC - no need to join this little soiree - that is unless you wish to Sir
Originally Posted by TinCupChalice
Absolutely! I had a good baseline of engine temperatures at different ambient temperatures using the Power Vision; after installing the relocation I was seeing a pretty consistent 15°; on the very hottest day it was around 12°. As the temperatures began to drop last fall it was more 17° - 19°.
I want to do some more testing this summer to get a better idea; I didn't have enough hot weather last year after the relocation went on; I'd like to get out on a 90°+ day and really see what it can do. My primary reason for going to the relocation was no more mess removing my PCS4C permanent oil filter for cleaning but relocating it out on the downtube appears to have added a bit more cooling, and that's bonus...
fxdli
Allow me to introduce you to TC
TC is one of the most diligent and thorough - when it comes to maintenance / upgrades / doing **** - on here
He post something in the form of results - it golden
You both hail from MI (iow results "should" be similar..., as environmental conditions not a factor)
He's seeing 19 degrees cooing as a max
Where as..., you're seeing 20 - 30 degrees cooling
10 to 15%...., equating to 20 to 30 degrees of cooling - means your motor started off running 200 degrees
Pretty cool for a twinkie to begin with -> 250 +/- is about nominal for modern day twinkie motor
So now your bike running in the 170 to 180 range
Not a pissing match..., nor am I labeling you less that truthful
Simply a quest for facts - of how such a discrepancy in results could exist
Feel free to respond..., or ignore
And should you wish to go on a little fact finding mission of your own..., to see if the **** I post is tight - knock yourself out
Yup
Ghost
