AIM VPC VP68LT clutch question
Old Apr 18, 2017 | 04:02 PM
128auto's Avatar
128auto
Question AIM VPC VP68LT clutch question
I am ready to order a VPC clutch part number VP68LT. Description said 40% clutch pull reduction. I already have Burly easyboy, can I use both? Am I going to gain grabbing pressure? I am not sure whether I should get a 68 or the next one up with 20% pull reduction and 20% more grabbing power. BTW I have a SE clutch spring. What do you think? Thanks
Old Apr 18, 2017 | 04:33 PM
OldEnuf2NoBtr's Avatar
OldEnuf2NoBtr
You can use the AIM VPC along with the Burly Easyboy and the SE spring. It should all add up to a fairly easy clutch pull in the lower and medium range of RPM's but in the higher RPM band the clutch will be a little bit more difficult to pull in because of the centrifugal force of the VPC. If you were having a clutch slippage issue before you won't have any after correctly installing the VPC.
Old Apr 19, 2017 | 11:10 AM
128auto's Avatar
128auto
Thanks OldEnuf2NoBtr. Regardless of easy clutch pull. Does it mean the VP68 light version will still improve clutch engagement and clamping force?
Old Apr 19, 2017 | 01:13 PM
OldEnuf2NoBtr
Yes it does.
Firemn17
General Topics/Tech Tips
Jul 21, 2016 12:25 PM
jeffbetrollin
Dec 8, 2015 02:15 PM
2006ultra
Apr 12, 2011 10:36 AM
FLHXXHLF
Jan 9, 2009 08:25 PM
Treasure
Apr 28, 2008 08:53 PM
