Not a "Build Thread," just my motor...
Old Jul 4, 2017 | 08:06 PM
  #131
misfitJason's Avatar
misfitJason
You should have adjusted them when the rockers were on and bolted down. You can do it the way you fit it but you have to very carefully bolt down the roller rockers now in the pattern listed in the manual to not break anything. You still need to wait for the bleed down before spinning the motor over to put the next cylinder on tdc.
Old Jul 4, 2017 | 08:10 PM
  #132
cggorman's Avatar
cggorman
I've only done hydraulic lifters once. I prefer solids for stuff like this (toys). If I recall, I set the rocker/pushrod adjusters to a prelim setting with lifters that were collapsed (slowly, in a vise), then did final adjustment after the first fire. Like Tarik, it's been a long time.
Old Jul 4, 2017 | 08:32 PM
  #133
robbyville's Avatar
robbyville
Great pic and happy Independence Day!
I've only done the pushrods with rockers and tops assembled.
Old Jul 4, 2017 | 08:45 PM
  #134
cvaria's Avatar
cvaria
Talking
i pulled a stunt like that. Not a best practice but, since i had to adjust my pushrods to test piston clearance.... and all was well. i labeled the positions of the rods when i removed the head. i later just dropped the rods back where they were with the adjustments already locked from before. i loosened the lock nuts and added loctite as i put each back.
my reasoning was basically, if they were solids that's what i would have done anyway. and the lengths was already set.
~700 miles later, no explosions yet.
Old Jul 4, 2017 | 08:47 PM
  #135
Nemosengineer's Avatar
Nemosengineer
Originally Posted by F86
Happy Independence Day, Dyna Forum!!!
Thanks. The engine looks great, grand progress. So... Is that a torque wrench in your hand or are you just happy to see us...*
* A traditional Navy greeting used among friends.
Couldn't resist. Have a wonderful holiday.
: Mike
Old Jul 5, 2017 | 01:41 AM
  #136
F86's Avatar
F86
Thanks, everyone. Just to be clear, I haven't adjusted anything yet... The pushrods are just sitting there right now. I was planning on breaking the adjusters loose and shortening them prior to installing the rocker arms, and then adjusting them properly after the rockers are fully assembled.
That's correct, yes?
I just confused myself wondering about the lifters possibly bleeding down on their own between now and Sunday, when I will complete the top and adjust everything... But since there is no tension on them, I realize that won't happen. It's just one of those things that pops into my head and worries me until it suddenly makes sense!
Thanks again for all of the input...
Old Jul 5, 2017 | 01:47 AM
  #137
F86's Avatar
F86
: Mike
Navy, huh? I thought it was a Mae West greeting!
Old Jul 5, 2017 | 01:50 AM
  #138
F86's Avatar
F86
Originally Posted by robbyville
Hey Tariq,
Quick question for you that may seem totally weird but... When you rotated the wheel to watch the pistons go up and down, where did that red oil come from? I used a light coat of Marvel's Mystery Oil on my cylinders and I put a little oil on the rings and such prior to putting the cylinders on but that's about it. I haven't rotated the engine yet.
Hey Robby, sorry... I didn't see your question earlier (and you're all buttoned up now anyway). I used a bunch of assembly lube around the rings as I fit the cylinders, and wiped some inside the cylinders after I washed them. When I rotated the engine it squeezed up to the top...
Old Jul 5, 2017 | 09:19 AM
  #139
cvaria's Avatar
cvaria
I dont think they will bleed down. If I'm understanding you. You just dropped them in there just cus?
Old Jul 5, 2017 | 09:31 AM
  #140
F86's Avatar
F86
Thanks Jason... I realize I didn't ask my question clearly. I definitely am NOT planning on bolting the rockers in on top of full-length pushrods... The rods and tubes are just sitting there right now. There won't be any pressure on them when I install the rockers, and then I'll adjust everything in the usual manner after the top is all assembled.
BTW, I assume from your name and avatar that you're a Misfits fan... If so, I can tell you some funny stories, like the time Glenn and Jerry ran around a bar screaming like little girls because a bat flew out of the bathroom...
