RPM's dropping
Old Jul 3, 2017 | 06:21 AM
Huckster's Avatar
Huckster
Question RPM's dropping
I have a 2012 FXDC with 4,300 miles on it now. Bought it new in January of 2013. This week while at a stop at a four way intersection the rpm' dropped to 700 down to 600 then motor killed. Normally the rpm' stay at 990 to 1,000. Bike was in first gear with clutch pulled in at time bike killed. Then ran fine, now it did it again but am watching and give it a slight rev when goes low. Would anybody know what this issue might be? I did have dealership install new mini ape handlebar with new grips. This was some time ago though. Possible cable adjustment needed on throttle? Hate to run into dealership if something I can handle. I did also clean air filter and checked spark plugs.
Thank you for any tips.
Old Jul 3, 2017 | 11:12 AM
Smogbob's Avatar
Smogbob
From another op try this.
Easy to do ...
Don't touch the throttle .. kill switch in the run position ...
Turn ignition switch on, wait for engine light to go off, turn ignition off.
Do this 4 times, then start the engine. This resets the computer.
Note: when shutting down the engine make sure it's at idle. Don't blip the throttle, and don't shut it down on cold idle. The computer remembers the last rpm at shutdown and sets the idle to that.
Old Jul 3, 2017 | 11:31 AM
Huckster's Avatar
Huckster
Thank you for that information! I will try that procedure. I rode bike today and all seemed fine. But I will do as you stated.
Thanks again!
Old Jul 3, 2017 | 11:41 AM
TinCupChalice's Avatar
TinCupChalice
Delete... whoa, wrong thread... OOPS... I have no clue how that happened; glitch in the Matrix, I guess
Old Jul 3, 2017 | 11:42 AM
nevil's Avatar
nevil
It wouldn't hurt to clean the IAC, especially if it's not been done before.
Old Jul 3, 2017 | 11:50 AM
TinCupChalice
Agreed! Now I'll respond in THIS thread; that was weird earlier.
OP, check out this video, it will help you see what you need to do. Turn on the ignition and turn the run/stop switch off and on as you spray the cleaner. I've just used carb cleaner and it's worked out great.
If you're venting your oily crankcase gasses back in to the A/C the IAC will get gunked up...
freeman73
2014-2024 Touring Models
Aug 5, 2020 11:27 AM
TiRider
Oct 22, 2018 09:49 AM
SA315B
Apr 9, 2017 10:38 PM
Tahaa
General Topics/Tech Tips
Jul 20, 2014 06:32 AM
johnica
Jun 18, 2008 06:34 PM
