Sputtering and dying out
Old Jul 29, 2017 | 12:23 AM
Dante Castro's Avatar
Dante Castro
Stage I
Default Sputtering and dying out
I have a 2007 Dyna street bob. It sounds like its running lean. It sputters and back fires when i let off the gas. Tonight, leaving work, the bike kept dying out and I had to keep on the gas to keep it on. Seemed to run better once it warmed up but still was almost dying out once i got home. I already changed the spark plugs and the line in the gas tank to the engine. Any ideas what could be causing the back fire, sputtering and it dying out?
Old Jul 29, 2017 | 10:46 AM
Ghost_13's Avatar
Ghost_13
I already changed the line in the gas tank to the engine.
Carb or FI
Off the top of my head - could be a dozen..., or so things
Fuel filter / fuel pump / injectors / fuel system / cracked hose in the fuel tank / tune way the hell off / electrical system breaking down / on..., and on..., and on
How far you willing to dig into this on your own..., vs. taking it to an indy and having them diagnose it (notice I did not say dealer)
If you're willing to go down the worm hole - we certainly can (I'm willing to stick it out)
Step 1 - you have a service manual
Ghost
Old Jul 29, 2017 | 11:00 AM
archergodwin's Avatar
archergodwin
Is it throwing any codes? ... another thing to try is checking your intake and exhaust for leaks. I used to use starting fluid (ether ) to spray intakes... if your idle goes up when you spray an area (not the filter area) then you may have found an intake leak.
As to the exhaust, find someone who smokes or get a incense stick... blow/hold smoke around your exhaust flanges and other exhaust joint areas.
Old Jul 29, 2017 | 12:41 PM
nevil's Avatar
nevil
You're giving very little info to go on.
Is the bike stock or do you have any mods to the intake, exhaust or tuner?
How many miles?
Before you buy any more parts to throw at it, try cleaning the IAC. Also check your battery cables at the terminals and ground connection.
Old Jul 29, 2017 | 12:47 PM
dyna rider's Avatar
dyna rider
Default Sputtering
What kind of tuner is in it ?
JohnnyE
Feb 7, 2016 08:40 PM
hell hound
Ironhead
Aug 11, 2015 07:06 PM
Streetrunner
Sep 22, 2014 03:04 PM
Tunernetwork
Mar 28, 2013 05:01 PM
eric95
Jul 11, 2010 11:14 PM
