Uptown Ripper
I completely agree that it'll be interesting to see what happens when you can confidently assume alignment is completely correct. The only reason I suggested running with stabilizers first is to make sure you actually experience both scenarios. As I said, if it seems better than ever without the links, you may lose motivation to reinstall them... Then we'll never know!
Anxiously awaiting ride reports! Thanks for documenting everything!
-Tarik
This is such an interesting quote, since by it's very design, the Dyna frame CANNOT do this. Even though I have a well-handling Dyna (and so do lots of people), sometimes I just can't believe Harley left this crucial task to a pair of rubber chunks. I wish they had just evolved the FXR frame a bit... I'm sure they could've modified it for a more "conventional" look (which was a concern at the time) and to hold a twin cam, without giving up the swingarm-to-frame mounting situation...
Now if we added an additional structure under the motor, use the same mounting points, just opposite side, and that supports the swingarm now. The swingarm mounting sleeve on the transmission is milled out making room for the new swingarm structural mount. The new swingarm mounting structure would take care of the pitch and yaw axis forces, and some additional bracing either from the bottom tubes or shock mounting points would be needed to take care of the roll axis forces:
Now there is no rubber in this system, and the structure is bolt on. The motor mounts now are strictly supporting the motor only. A couple of pics of some frames where I got this crazy idea:
In all these cases, the swingarm is bolted to the frame, helping with keeping the steering head and swingarm mount in the same position. Of course there is the loads trying to twist these locations apart.
Back to reality now, lol.
Dave
Dave
Google "Norton Isolastic frame". There is an AMF connection...
https://www.nortonclub.com/docs/Stra...ando_Frame.pdf
I do not know much about Nortons, but it appears they also attach the swingarm to the motor, and not the frame?
As far as chain tension, is there enough movement to cause an issue? Remember, we are in the Twilight Zone right now talking about this, lol.
Dave
Here are my rods, one is OEM vs the beefy ones from Darkhorse. I did this for my 107", I can see your 117" didn't like them.
Dave
I wanted to give Carl at Legacy Baggers a huge thanks. The engine tags are aluminum and the Highrider emblem is acrylic. I still have to get the words and border filled with paint to match the tank emblem for the Highrider emblem:
I am hoping to get that part figured out.
Dave
