question for HD mechanics
Old Oct 27, 2017 | 10:20 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
If you know how to pull the fuel line off, pull it off and reseat it. It's also possible the Turn Signal Security Module may have tripped by going horizontal. Turn the ignition on and cycle the run/off switch a few times, turn off ignition. Then try starting again. Did you check to make sure the plugs were connected at both ends. Double check the crank position sensor, left front of engine close to the oil filter.
Old Oct 28, 2017 | 08:06 AM
edteach's Avatar
edteach
I pulled the plugs and they are black but not completely fouled out. Plug wires were tight. I can replace the plugs, they are nickel NGK so only a couple bucks each.
Old Oct 28, 2017 | 05:51 PM
leafman60's Avatar
leafman60
I AM a H-D mechanic. Do what they taught us in H-D school. This is very simple.
Just stand it up and then slam it down on the other side and that should set everything straight.
Old Oct 28, 2017 | 05:52 PM
leafman60's Avatar
leafman60
Just kidding.
Take the other suggestions but also check your intake manifold and make sure that it has not popped off from the cylinder(s).
Could be anything.
crabio
Jun 20, 2019 03:50 PM
0maha
EVO
67
Nov 16, 2017 12:01 PM
jeeper101
Jan 1, 2017 07:21 PM
FinalShot
Jun 3, 2014 06:50 PM
softale_03
Exhaust System Topics
Apr 23, 2005 06:51 PM
