Handling Modications
Old Nov 24, 2017 | 04:15 PM
CaptainAwesome's Avatar
CaptainAwesome
Default Handling Modications
Looking to get a good topic going on everything that can be done handling wise on a Dyna. There doesn't seem to be anything definitive about it that I've found yet.
Suspension
Brakes
Stablizers
Ergonomics
Tires (type and size)
Geometry (Rake and trail)
Where to start, biggest bang for the buck, what's hardly worth it, ect.
I know these aren't sport bikes, but I see no reason why we can't make them handle better if we want to do so. A Harley I can flick with my hips sounds like the ultimate bike to me.
Old Nov 24, 2017 | 04:27 PM
fxrnutt's Avatar
fxrnutt
I've done about all you can do. Still have the LR raked trees but probably won't change em out.
CaptainAwesome
The biggest change I've personally experience on any of my last bikes is changing the rear suspension geometry. A taller rear tire improved how quick the bike was to lean (but also messed with the speedometer), but shorter dog-bones made the biggest difference, basically getting your tail up higher. I'd say on the SV650 I did it to it made a 20-25% improvement in how easily it wanted to dive into a corner or be flicked. On a Harley I would assume putting on longer rear shocks would have this effect.
I've also noticed on my LR-S that I can have a pretty strong improvement in how the bike handles by how I sit on the bike. If I lean over the tank, keeping my back straight, I can flick the bike easier with my hips. However the bike isn't set up for this so maintaining that seated position for long doesn't happen.
Pegs under you make moving it way easier than in front of you.
Wide tires do effect how eager it is to lean, but they also seem to work much better on powerful bikes in power delivery. Plus they look cool... so there's that.
Brake pads make a huge difference. I threw Sinister HH pads on my last bike, night and day in my opinion. Stainless brake lines are also supposed to help since they don't flex the same, but I haven't done this personally.
Just my experience with it. Looking forward to learning a lot more as I'd like to get more out of my bike.
And yes. It's a Harley, not a sportsbike. But that's like saying I can't try to up the power on a Ninja 250 with a couple mods, lol.
Old Nov 24, 2017 | 04:29 PM
CaptainAwesome
What's made the biggest difference for you?
I'm thinking longer rear shocks is the best starting point, but that's just theory. Suggested order? Worth the money?
Thanks
Old Nov 24, 2017 | 04:31 PM
cggorman's Avatar
cggorman
IMO by price/performane
Rider training, then...
1. Proper alignment
2. Tires
3. Brake pads
4. Big rotor conversion
5. Mid-grade shocks/springs/damping
6. Drivetrain stabilizers
7. Cartridges and high-grade shocks
8. High-grade lightweight brakes
9. Weight loss
Old Nov 24, 2017 | 05:38 PM
W.Glide's Avatar
W.Glide
1. Proper alignment
2. Tires
3. Brake pads
9. Weight loss
Me personally, i'd put # 7 up towards the top. At least on my wide glide.
I also realize you haven't ran your rig since your bad crash, but I have done dam near everything you have listed, and Ohlins front and rear made a HUGE difference in my glide.
Old Nov 24, 2017 | 06:00 PM
fxdlx's Avatar
fxdlx
1- loose the stock mushy suspension. (front/rear and hike it up for clearance)
2- stabilizers
3- alignment(shouldn't be that far off anyway)
4-Brembos
Old Nov 24, 2017 | 06:02 PM
rbdub474's Avatar
rbdub474
Here’s my plan.
13.5” ODC rear shocks, adjustable w/ reservoir
+2 ODC inverted front suspension, adjustable
Brembo radial mount calipers
Magnum Shielding brake lines (gives better brake application)
BMC The Wall seat
Will be replacing wheels with lighter ones wrapped in Pirelli Night Dragon tires
Will be replacing front rotors with 13.5” ones
Also different bars
This plus some engine work that’s being done and it should handle relatively well.
Current state:
Old Nov 24, 2017 | 06:12 PM
fxdlx's Avatar
fxdlx
Originally Posted by rbdub474
Here’s my plan.
BMC The Wall seat
Also different bars
Thats gonna be nice. What front end is it?, I see the ODC is that the brand?
Old Nov 24, 2017 | 06:17 PM
CaptainAwesome
Let me know how that turns out, Ive got the same bike and have been looking at a lot of tge same modications. Im only in the planning stage though.
