Electrical Issue
Old Jan 4, 2018 | 10:56 PM
Jsin23's Avatar
Jsin23
Thanks for all the replies everybody. So today when I had a sec I went out and pulled the battery cover and put a volt meter to the battery with the bike off. The meter was showing 27 volts. When I would start the bike and then put the meter on it, it was showing up to 30 volts. Any thoughts? I'm thinking that the regulator is bad.
Old Jan 4, 2018 | 11:39 PM
NORTY FLATZ's Avatar
NORTY FLATZ
27?
You reading the correct scale on your multimeter?
If not, you've got the only 27V Harley in existence!
Unless you've one of those newfangled WideGlide Livewires!
Ok, seriously, perform a voltage check statically and under load. Then a voltage check after start up. These can all be done across the poles.
Should see something like
12.5+ static
11+ under load
13.5+ after start up.
Old Jan 4, 2018 | 11:53 PM
Jsin23's Avatar
Jsin23
Originally Posted by NORTY FLATZ
27?
12.5+ static
11+ under load
Right now I've got the battery on the tender to ensure the battery is at a full charge. Tomorrow I will test it out again to see what I get. I had the meter set to read up to 200 volts. The meter doesn't have a lower setting. When I put the meter on the battery before start up it was reading 27 volts, running it was reading 30 volts and after shutting it down it was still reading 27 volts. Tomorrow I'll take some pics of the meter if the reading is still off.
Old Jan 5, 2018 | 07:17 AM
Jackie Paper's Avatar
Jackie Paper
You need to pay someone to fix your problem. And toss the meter in the trash.
Old Jan 5, 2018 | 03:07 PM
Jsin23's Avatar
Jsin23
I'm just about there lol....If I can save myself a few hundred and do the work at home though I'd rather do that. I'm going to borrow a meter today to verify that mine is or isn't defective.
Old Jan 7, 2018 | 03:32 PM
Jsin23's Avatar
Jsin23
Well it looks like I've got a bad stator. Used my buddies meter and it was showing 12.5 volts sitting but under load there was no change. While the bike ran and even hitting about 2000 RPM the voltage never changed. Constantly around 12.5 to 12.7.
Old Jan 7, 2018 | 05:36 PM
Jackie Paper
Before going for stator, unhook the three wire plug from it at the regulator. Then at 2000 rpm, and with a good AC meter set on AC, connect your meter across two wires. Three check combinations for the three-phase system. What is your AC volt readings?
And be careful, that AC can hurt you.
tmultra
Apr 17, 2017 01:26 PM
DaveJFuller
Jul 1, 2014 08:53 AM
broncobob
Apr 17, 2013 09:27 AM
leepetersusn
Aug 22, 2011 07:26 AM
Bubba Zanetti
May 26, 2007 05:20 PM
