Engine light coming on
Old May 25, 2007 | 09:36 AM
Bubba Zanetti's Avatar
Bubba Zanetti
Default Engine light coming on
I ride an 04 Electra Glide Classic. It has just under 26000 miles on the clock. 2 days ago I hit the starter and it seemed to clunk a little bit. About 3 seconds later the engine light came on and stayed lit for about 10 seconds, then went back off. Now everytime I start the bike, the light comes on as normal then goes out, I start the bike, then 3 seconds later the light comes back on for 10 seconds and goes back out again. Anyone got a clue whats up? I guess I'll have to take it to the dealer and hook it up to the scanner.
Old May 25, 2007 | 09:42 AM
txhdrider's Avatar
txhdrider
Default RE: Engine light coming on
You might want to check your battery voltage. Sounds like you might have a battery going bad.
Just my .02 worth,that was what was mine was doing last month. I had it hooked up to a scanalyzer that was what it said the problem was and my battery was just 2 yrs old. Good luck, I hope thats all it is.
[IMG]local://upfiles/24050/736BCB23A40B48F483387F11D7AF392B.jpg[/IMG]
Old May 25, 2007 | 10:39 AM
Bubba Zanetti
ORIGINAL: txhdrider
I never thought of that. I will hook up the Battery Tender when I get home tonight and see if that cures it. Will the light stop coming on if thats the case? It sure would be nice to not have to pay for a scan, if all I need is a battery charge.
Old May 25, 2007 | 01:23 PM
ponesma's Avatar
ponesma
Try this procedure in the DIY section. You might be able to find out what the code means.
https://www.hdforums.com/m_43975/tm.htm
I did this on mine when I installed the alarm, worked like a charm.
Old May 25, 2007 | 02:35 PM
Bubba Zanetti
ORIGINAL: ponesma
Thanks ponesma, some very good info there. I will give it a try and see what comes up. Thanks again.
Old May 25, 2007 | 02:42 PM
ponesma's Avatar
ponesma
ORIGINAL: boe1971200
No Problem, good luck. It was very simple to check and clear the code. I don't know what I would do if it was not for this forum, other then pay the dealer a ton of $$$.
Old May 25, 2007 | 02:52 PM
oldfartjc's Avatar
oldfartjc
I had a similar problem with the engine light (but not the starter) coming on as you described over a year ago and and read out a "U1097" code. I cleared it the way it said to and it hasn't returned. The only thing Icould remember doing a few daysbefore I noticed this happening wasinstall the Smart Siren II. I have no idea if that caused the code but it never came back once I cleared it.
Old May 25, 2007 | 10:39 PM
wideglidebob's Avatar
wideglidebob
just turn it off
Old May 26, 2007 | 05:20 PM
Bubba Zanetti
ORIGINAL: txhdrider
It was not the battery, I charged it last night, and started the bike to go to work this morning and the light still comes on. I guess I'll have to clearthe codethe way listed above.
KINGASOBEE
Mar 11, 2017 09:50 AM
Pcrebuilder
Dec 15, 2014 09:25 AM
DaveJFuller
Jul 1, 2014 08:53 AM
leepetersusn
Aug 22, 2011 07:26 AM
jb bill
Dec 26, 2005 05:28 PM
