FXDI wont start, any ideas??
Old Feb 17, 2018 | 03:52 PM
Scott Bergeski's Avatar
Scott Bergeski
Stage II
Default FXDI wont start, any ideas??
06 Dyna FXDI, motor cranks but won't start. Bike has power but won't start. Already changed battery, new plugs and pulled/cleaned the fuses. Any ideas, advice??
Old Feb 17, 2018 | 03:56 PM
2500hdon37s's Avatar
2500hdon37s
well if it cranks over...
Check for spark and fuel.
Old Feb 17, 2018 | 04:17 PM
Scott Bergeski
Stage II
Replaced with fresh fuel, when checking for spark, didn't see anything. Could it be a bad stater or bum plugs? Just bought plugs from the dealer....
Old Feb 17, 2018 | 07:09 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
What did you just do to it. Disconnect the plug wires put some plugs in the wires, ground to the cylinder and crank the engine, is there spark? Is the fuel disconnect connected to the fuel tank securely?
Old Feb 17, 2018 | 07:12 PM
im's Avatar
im
We can not see the bike and have no history.
Is this a new bike to you?
When did it operate OK?
Did you change anything on the bike?
Why did you change the battery?
Why did you change plugs?
It would seem like the bike cranks so you need to look for fuel and spark.
Does the fuel pump prime when the ignition is powered?
Does the bike indicate any error codes?
Old Feb 18, 2018 | 01:41 AM
shovelheadroad's Avatar
shovelheadroad
Try a little quickstart. If it catches/pops...you've got a fuel issue. If not...you have no spark.
Old Feb 20, 2018 | 03:10 AM
Spanners39's Avatar
Spanners39
Ok, usually this is the crank position sensor, it should test at 0.9 ohms or similar, a duff one will show 0 ohms and they usually fail when the bike is shut down and so it won't start again.
Just a note on EFI bikes, they won't spark if you take the plugs out, to test for a spark you need to leave the plugs in and put another set of plugs in the plug caps and crank her over with the plugs earthed on the motor.
Old Oct 24, 2024 | 04:09 PM
Juan M.'s Avatar
Juan M.
Having same issues, ​​​​​​So if I have spark is Not the CKP sensor?
Old Oct 24, 2024 | 04:11 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Start a new thread, give bike details and explain what the problem is.
This thread is 6 years old.
Old Oct 24, 2024 | 06:24 PM
Rounders's Avatar
Rounders
Start a new thread. It is not like their is wealth of info in this one. I am not against adding to a thread with lots of great info. If it is a strong spark, I suspect not cpk. But you can measure the AC, with plugs out it will be high. plus I am not sure it is 100% accurate. If you year , the wires go back to ignition, use weed wacker line to to pull wires back and forth through loom.
Harpo568
20
Apr 21, 2019 07:52 PM
MNroadglideguy
General Topics/Tech Tips
May 19, 2017 05:45 PM
yellowpearlfb
Electrical/Lighting/Alarm
Oct 11, 2015 03:43 AM
Plumbwader
EVO
73
Oct 5, 2015 08:18 PM
npsocal
Carburetor Related
Aug 11, 2015 05:26 PM
