Gas indicator problem
Old Apr 1, 2018 | 09:14 AM
JohnMn's Avatar
JohnMn
The instructions pretty clearly state that an initial st up period is needed for the gauge to work.
aka; you gotta burn a take full of gas through it so the gauge can read itself.
I wouldn't panic too much until you had a chance to do that.
While your waiting for riding weather,, read the instructions again.
Old Apr 1, 2018 | 09:20 AM
Bob_fxdb's Avatar
Bob_fxdb
Hehe aaaah! That’s good to hear! I would rather burn the fuel then suck it out again
I thought I destroyed the sensor when I was removing the tank...
Old Apr 1, 2018 | 09:23 AM
Bob_fxdb's Avatar
Bob_fxdb
Originally Posted by FXD2003Rider
Now check if you get a signal at both connectors....
yes! Just need to borrow a multi meter!
Old Apr 1, 2018 | 09:39 AM
FXD2003Rider's Avatar
FXD2003Rider
Administrator Emeritus
Here's the link to the instruction sheet...
Old Apr 1, 2018 | 09:58 AM
Bob_fxdb's Avatar
Bob_fxdb
Much appreciated!
fyi, this is not a new installation, I just disconnected the tank and reconnected all of it again, except for the left cap connection. I hope the instruction also apply for this situation.
“When adding fuel to the vehicle it is recommended you add at least 2 gallons (1 gallon for 2.1 gallon SportsterŽtank) of fuel to update the fuel and range displays. If the fuel display does not update immediately after the vehicle is put in motion the fuel and range displays will slowly update over the next 30 miles.”
Old Apr 27, 2018 | 09:07 AM
Bob_fxdb's Avatar
Bob_fxdb
Just an update, Ive ridden over 150km(90miles) and still have the same problem.
Old Apr 28, 2018 | 07:38 AM
AFMM3's Avatar
AFMM3
The fuel sending unit in the tank gets it's power from the original fuel gauge on the left side of the tank. The signal is then used by the speedometer. You need an original style fuel gauge in addition to using the speedometer.
Old Apr 28, 2018 | 08:24 AM
Bob_fxdb's Avatar
Bob_fxdb
Well haha, that’s a weird setup from hd...
There have to be a way to get around this. What if I connect the wires together? 😂
Old Apr 28, 2018 | 02:05 PM
Bob_fxdb's Avatar
Bob_fxdb
I mean, close the circuit...
glv1@comcast.net
Jun 29, 2018 08:37 PM
ppilotmike
EVO
13
Jan 15, 2017 07:34 AM
banditgrrr
Jul 3, 2014 07:15 AM
pc100
EVO
14
Aug 4, 2013 03:40 PM
Curdog
May 15, 2012 11:29 PM
