Sputhe chassis stabilizers?
Old Oct 25, 2019 | 07:14 PM
  #31
Bob_fxdb's Avatar
Bob_fxdb
When mention alignment, I do get a wobble when not holding on to the bar in low speed. Yeah, alignment tools will be ordered... Hope this fixes the brake vibration, but I kinda doubt it hmmmm
Old Oct 25, 2019 | 07:17 PM
  #32
Bob_fxdb's Avatar
Bob_fxdb
Originally Posted by John CC
Is the Sputhe mount touching the brake line or switch? I have the Predator front and Sputhe rear and do not have any braking issues, but I did have to move the brake line to keep it from interfering with the mount.
I twisted the brake line so the brake switch wouldnt interfere with the sputhe bracket. No touching, tested it without shocks and rear tire installed
Old Oct 25, 2019 | 07:23 PM
  #33
cggorman's Avatar
cggorman
I'm also running the Lyndall Extreme pads front and rear.
With no front link, the drivetrain is still not constrained to a plane. With that setup, the drivetrain could pivot around the rear mount and the stock top link is pretty compliant.
Three heim links of equal length would be quite unforgiving of any imbalance, vibration, or runout.
Again, I'm mostly speculating here. I changed pretty much everything at once and did a 90% alignment before the first shakedown run. I also have a little 88" with pretty light and rigid exhaust so it's not exactly apple to apples.
Old Oct 25, 2019 | 07:44 PM
  #34
Bob_fxdb's Avatar
Bob_fxdb
I also have a little 88"(stock) with late dyna frame(06) and light exhaust (TBR). Thanks for taking your time and speculate. Just ordered digital alignment tools
Old Oct 25, 2019 | 08:16 PM
  #35
cggorman's Avatar
cggorman
No problem!
Wouldn't hurt to check that the rear rotor is straight/flat. I think the stock '06 rear caliper is floating, so it should be pretty tolerant of some minor runout. Maybe .010"? Mine isn't (Wilwood GP310) and I'm familiar with monoblock calipers so I'm pretty **** about rotor runout.
Old Oct 26, 2019 | 12:20 PM
  #36
multihdrdr's Avatar
multihdrdr
Originally Posted by cggorman
... I think the stock '06 rear caliper is floating ...
Not until 08
Old Nov 29, 2022 | 05:29 PM
  #37
Shallah2's Avatar
Shallah2
6th Gear
Default Same!!!
Hey BOB I have the same issue! Did you find any fix? Got an 09 fatbob with the predator and the sputhe in the rear
Old Nov 29, 2022 | 09:51 PM
  #38
Bob_fxdb's Avatar
Bob_fxdb
Yeah actually, I did a lot that season; I overhauled my cylinders and of course upgraded everything that I could. Engine got realigned and torqued to specs.
tbh I suspect it was the rear wheel bearings, because I also swapped them out and they were BAD 😅 now it’s like riding on clouds 👌
Mr98z71
May 9, 2019 09:58 PM
paulvs
Nov 8, 2017 06:54 PM
wideglideCVO
Aug 2, 2017 03:15 PM
zamiam
Oct 13, 2015 08:08 AM
Ironhead.Chris
Jul 8, 2015 09:24 PM
