Clunking front end
Old Jun 11, 2018 | 09:24 PM
crusader1xxx's Avatar
crusader1xxx
More then likely it’s the normal ( for Harley) front fork clunk that the stock suspension causes. If you have never changed the front fork fluid...nows the time, and while your in there get a good set of Traxxion springs....
oh, you do realize you posted this in the dyna section.......
Old Jun 11, 2018 | 10:50 PM
buddybob's Avatar
buddybob
Dyna section? Oops. LOL. Thanks. Would swapping to those $90 Progressive springs alleviate the clunking?
Old Jun 12, 2018 | 02:56 AM
vonh12's Avatar
vonh12
Progressives might and heavier weight fork oil might too, if that's the problem.
Old Jun 12, 2018 | 08:53 AM
crzoomb's Avatar
crzoomb
Old Jun 12, 2018 | 09:28 AM
buddybob's Avatar
buddybob
I'm ordering the washer now
Old Jun 12, 2018 | 02:09 PM
crzoomb's Avatar
crzoomb
I had the same issue, new washer, no more clunk.
Old Jun 12, 2018 | 04:43 PM
buddybob's Avatar
buddybob
It wasn't the washer. The nut wasn't tightened to 80 ftlbs, but that wasn't the issue either. I guess it's fork oil next. Then, if that's not it, it spring replacement time. It'll get found, one way or another. Then, hopefully, everyone can learn by my experiences too.
Old Jun 12, 2018 | 05:07 PM
bad tappets's Avatar
bad tappets
Have you checked neck bearings? Are you sure the clunk is in the forks? Have you checked exhaust mounts? Get on bike and rock handlebars, roll forward hit the brakes,etc... Get a rubber mallet and hit the front wheel, jack up the front end and hit with tire with mallet, listen for anything loose.
Old Jun 12, 2018 | 05:12 PM
buddybob's Avatar
buddybob
It's definitely something with the front end (fork area). I've shook the thing a few times. I'll go out a little later and roll it and slam on the front brake, but, braking hard doesn't seem to affect is while riding. It's all about bumps and potholes. It's not bottoming out either.
Old Jun 12, 2018 | 05:23 PM
Camarosx2's Avatar
Camarosx2
Had same noise on my 02 fxsti adjusting my neck bearings solved my problem.
