Clunking front end
Old Jun 12, 2018 | 05:29 PM
buddybob's Avatar
buddybob
Tightening the nut under the top neck thing? Yea....I tried that already.
Old Jun 12, 2018 | 05:56 PM
RPMorey's Avatar
RPMorey
I chased a strange clunk in the front end on my 2008 Nightrain last year. I tried everything that I could think/read of. I put a wrap of electrical tape around the edge of the glass headlight housing. Between the glass and the headlight bucket. Pot hole clunk gone.
Old Jun 12, 2018 | 09:07 PM
crusader1xxx's Avatar
crusader1xxx
The clunk has nothing to do with triple tree washers, neck bearings etc etc....it’s in the forks, I guarantee it.
change your fluid, add some decent springs and oil....get your preload and SAG set properly and your clunk will be gone and your bike will ride much better
Old Jun 12, 2018 | 11:00 PM
buddybob's Avatar
buddybob
And that's what I'll be doing next. Ordering Progressives and oil.
Old Jun 13, 2018 | 09:16 AM
multihdrdr's Avatar
multihdrdr
If you're talking about "Suspension" Fork Springs (as opposed to "Top Out" springs), why do you think changing them would help with "Topping Out" ?
Unless you're changing to "Lighter" Springs
Old Jun 13, 2018 | 09:30 AM
buddybob's Avatar
buddybob
Let me explain what's happening. When exiting my driveway, or hitting a small pot hole, the front end "clunks".as if, on the rebound, it's hitting like a slide hammer being fully extended. Just "WHAM". So, yea. It's a topping out problem, not bottoming out or dampening (the ride is actually perfect). I guess that's the best I can explain it.
Old Jun 13, 2018 | 10:16 AM
multihdrdr's Avatar
multihdrdr
Ok...So I shortened the question?
Why do you think changing the Fork Springs would help with "Topping Out" ?
Old Jun 13, 2018 | 03:27 PM
buddybob's Avatar
buddybob
I'm not an engineer. What other recommendation might you have? There are no loose nuts anywhere. The steering head bearing have no play. I just went outside and push the bike forward, then slammed on the front brake. The sound is thereon the rebound, emanating from the forks.
Old Jun 13, 2018 | 03:46 PM
bad tappets's Avatar
bad tappets
How long have you had the bike? Did the previous owner put stiffer springs in, or raise the front end? Change in oil from stock? Any other mods to the forks? Sounds like a topping out problem. Heavier oil could help maybe. Is there a broken rebound valve? May have to pull forks apart and investigate.
Old Jun 13, 2018 | 03:50 PM
user 7172984932's Avatar
user 7172984932
Sounds like a valving issue to me if its that serious
Talk to Race Tech they are experts and may have a solution
