Fxdwg engine squealing
Old Jun 20, 2018 | 12:54 PM
NORTY FLATZ's Avatar
NORTY FLATZ
I had a squeak like that on my Evo, many years ago. Turned out to be an exhaust heat shield. Only did it at idle and when hot.
Go get it to squeak again, put your shoe on various parts of the ex pipes. You may find one that quits squeaking once pressure is placed on it. That'll be your huckleberry.
Old Jun 21, 2018 | 11:22 AM
Sknight14's Avatar
Sknight14
4th Gear
Took off all heat Shields, checked all motor mounts. Can’t figure this out! Only does it when hot.. thinking it has to be internal. Off to the shop I guess
Old Jun 21, 2018 | 09:09 PM
crusader1xxx's Avatar
crusader1xxx
Sounds primary to me, I would change the fluid unless you already have, then I would check the clutch basket.....
watching aposed to listening I could swear it was the horn cover.....
Old Jun 22, 2018 | 11:24 AM
Sknight14's Avatar
Sknight14
4th Gear
I’ve pressed on/ taken off anything external that moves.. I’ve changed the primary fluid but thinking of popping the cover off to see
Old Jun 22, 2018 | 11:27 AM
Spike_351's Avatar
Spike_351
Have you checked the tension on your primary chain or the condition of your tensioner? Probably not the problem but it wouldn't hurt to check just in case.
Old Jun 22, 2018 | 11:58 AM
Sknight14's Avatar
Sknight14
4th Gear
chain seems pretty tight. 3/8” play if that unless you really push it
Old Jun 22, 2018 | 12:17 PM
Spike_351's Avatar
Spike_351
It's a 2001 right? So that's a twin cam 88? I have heard of some of the earlier 88''s had cam bearing issues, once again a long shot, but if you've gone over everything else I guess it wouldn't hurt to check.
Sknight14
Engine Mechanical Topics
11
Oct 17, 2024 05:09 PM
Mcdoua1
Aug 6, 2020 05:55 AM
300sd1982
Oil Archive (no new posts)
Jan 16, 2019 11:01 AM
badfl97
Shovelhead
13
Nov 8, 2018 04:19 PM
LAFO
General Topics/Tech Tips
Apr 19, 2018 11:22 AM
