Why an idle cable?
Old Jun 28, 2018 | 07:49 AM
The Twigster's Avatar
The Twigster
Default Why an idle cable?
So......on my '08 Dyna I snapped the idle cable tube at the adjusting nut and ordered a new one. While installing the new one I question as to even needing one. Someone correct me if I've missed something. Since the butterfly opens with the throttle cable and closes because it is spring loaded, what does the idle cable do? The idle is set by the computer so there's no adjustment needed for that like on the old carbs. So right now I'm riding with only the throttle cable and don't see any difference.
Old Jun 28, 2018 | 07:51 AM
SixDD's Avatar
SixDD
From: Depends on who wants to know.........and why.
Great question. ***subscribed***
Old Jun 28, 2018 | 08:09 AM
MURPHCC1's Avatar
MURPHCC1
The butterfly valve spring is not strong enough to make the whole thing return.
There is NO designated return spring (Like a car) so the idle cable is mechanical advantage to return to idle. Great safety feature as far as Im concerned......back in the day a broken return spring would most times result in a full throttle run.....NOT GOOD!!!
Old Jun 28, 2018 | 08:11 AM
archergodwin's Avatar
archergodwin
It's a safety thing thought up by someone who probably isn't a rider. The thought is, if your throttle cable broke while going down the road, or a WOT, you can 'pull' the throttle closed with the other cable.
It probably happened once.. or twice maybe... and some bureaucrat somewhere 'had a mission' to save us all.
Old Jun 28, 2018 | 08:25 AM
The Twigster
Yah, I thought of that too but the kill button would over ride runaways.
Old Jun 28, 2018 | 11:35 AM
JohnMn's Avatar
JohnMn
Sure,, but only after the few seconds pause of awareness and action that is the human condition of brain and muscle. A lot can happen in 1.7 seconds at WOT in traffic,, that an already conditioned wrist twist of throttle response could avoid.
As already said,, the second "idle" cable was added as another safety feature along with the changes in throttle body of EFI, lighter springs and ECM engines.
HD is not the only one with this now decades old advancement in control.
Vale
Apr 14, 2017 11:23 PM
txfxstrider
Apr 25, 2012 05:23 PM
WG2011
Aug 15, 2011 07:58 AM
rd_king_rider
Sep 1, 2008 02:01 PM
dynakeith
Aug 26, 2006 10:09 PM
