Fork Seal install
Old Jul 30, 2018 | 02:54 PM
tcazes's Avatar
tcazes
ok great. just checking. use some sort of grease to lube it up and it should slide right in. i dont do the freezer because naturally, rubber gets hard and more brittle the colder it gets. not my cup of tea.
Old Jul 30, 2018 | 03:46 PM
mang0's Avatar
mang0
wow, little lube does wonders :-) went right in without too much trouble. Thanks.
Old Jul 30, 2018 | 03:56 PM
mang0's Avatar
mang0
alright next question....how do you torque the seat pipe screws? i knopw the seat pipe is spinning as i try to tighten it
Old Jul 30, 2018 | 04:35 PM
tcazes's Avatar
tcazes
Seat pipe? You talking about the piece in the bottom under the fork tube, with the bolt from the bottom of the fork? If so, completely assemble the fork leg and tighten that bolt last. The spring tension will hold it in place
Old Jul 30, 2018 | 04:38 PM
mmesa005's Avatar
mmesa005
You need a Fork Seal installation Tool. It has enough weight to generate the force needed while not damaging the seal.
https://www.jpcycles.com/harley-dyna...spension-tools
Old Jul 30, 2018 | 04:43 PM
tcazes's Avatar
tcazes
People been using PVC before these tools were ever invented. Are they nice? Yes. Necessary? Absolutely not
Old Jul 30, 2018 | 07:03 PM
mang0's Avatar
mang0
electric impact wrench from harbor freight did the trick for $40. So i have the forks all assembled (no springs or fluid yet). One of them slides easier than the other, not sure why or if it will matter once the springs and oil are in there. It's been a learning experience for sure
Old Jul 30, 2018 | 07:10 PM
tcazes's Avatar
tcazes
lol lube helps EVERYTHING! lmao. is it tougher AFTER everything is put together? or before you screw the top cap on just sliding the tube is more difficult? you shouldnt have needed an impact. the spring tension alone should have been more than enough.......
Old Aug 6, 2018 | 06:15 AM
mang0's Avatar
mang0
Many thanks to all your feedback, had the bike out yesterday and it handled exceptionally well on the highway and in the twists. I think i had been slowly losing oil over the past year or two and hadn't realized how the handling deteriorated. In retrospect, a couple things i would have done differently would be to loosen the pinch bolts more as i can see some tiny scratches on the fork tubes where i slid them out. Once i had the forks assembled, i should have covered the new black sliders up with some of the padding they came with--somehow i managed to get a tiny nick on one of the lowers. I learned a lot, and once again, appreciate all the help this forum has to offer :-)
flhxmc
Jan 22, 2013 10:32 AM
SkyRider
Apr 24, 2008 07:56 PM
JDixon
Mar 12, 2008 07:34 PM
20FXST06
Sep 10, 2006 12:20 PM
20FXST06
Sep 10, 2006 01:34 AM
