Vibration cured Finally!!
Old Aug 29, 2018 | 11:10 AM
Huggerbugger's Avatar
Huggerbugger
Default Vibration cured Finally!!
After a year of replacing parts, finally got around to the rear mount. Back to normal! Factory mount cured it for $100. The old one looks perfect, so maybe it was just loose, don't know. My Indy changed it. Now to cure that shuddering at idle.
Old Aug 29, 2018 | 02:12 PM
cggorman's Avatar
cggorman
Yay! Now you know, if it happens again,
Old Aug 29, 2018 | 02:48 PM
tcazes's Avatar
tcazes
i think that rear mount is often overlooked. did you cut the hump out of the middle like the service notification for the front mount?
Old Aug 30, 2018 | 03:11 PM
NORTY FLATZ's Avatar
NORTY FLATZ
And to think we paid extra for this!
Old Aug 31, 2018 | 12:21 PM
TickTock's Avatar
TickTock
Have you tried Heavy Fork Oil? Goes a long way to solving that shudder problem.
Old Sep 1, 2018 | 11:33 AM
Huggerbugger
Bike is at a shop. He's changing both mounts and swears that's the problem, even though I just changed the rear mount. Fork oil doesn't go bad in one day. The shuddering is caused by engine riding on the cross member.
Old Sep 6, 2018 | 06:55 PM
Huggerbugger
Fkd again!! The rear mount was the problem but the new one caused the engine to bang against the cross-member. Tried another shop, mechanic acts like he's a brain surgeon, puts two new mounts in, charges me double the retail price for the mounts and the hump at the front is causing vibration. $540 to change two motor mounts.
Old Sep 6, 2018 | 09:10 PM
crusader1xxx's Avatar
crusader1xxx
You need to learn how to work on your own bike, or pay up sucker as Jesse James use to say...
The price you paid is not out there, probably the going rate for two mounts....although you could have gotten a predator front mount and a stock rear for that price and installed then yourself....
Old Sep 6, 2018 | 09:25 PM
Huggerbugger
I would do my own work if I had a garage and a lift.
Old Sep 9, 2018 | 02:53 AM
tcazes's Avatar
tcazes
you dont need a garage or a lift to do that. hell you dont need a garage or a lift to do any work on a bike. thats a cop out dude. i know i sure as **** have never had either and never had any issues building bikes. pretty sure the old timers on here would say the same.
