Radial Mount vs Ness Big Brake kit
Old Jul 29, 2020 | 02:58 PM
  #31
El Chiguete's Avatar
El Chiguete
Originally Posted by joecha56
Which bracket?
The one that holds the radial caliper and moves it to where it needs to be for the Ness Big Brake rotor size.
Old Oct 9, 2020 | 10:28 AM
  #32
M4dm4x's Avatar
M4dm4x
Brembo front and back. Calipers and master cylinders. Bike stops crazy fast. Had to do some fabricating. Well worth it
what rear master did you use and how did you go about mounting it? I’m want to a radial rear caliper and I think it puts very poorly with Harleys rear master, or I need to rebuild it.
Old Feb 9, 2021 | 07:29 AM
  #33
Connor McCaughn's Avatar
Connor McCaughn
Stage II
Default Blue Bob
Originally Posted by Blue Bob
Once the pads and rotor are seasoned there will be no noise. For the first few hundred miles you will hear a slight flutter but absolutly NO feed back thru the lever.
On my conversion I went to great care to ensure the pads contact the entire surface of the rotor.
Blue Bob I was wondering if you still make these or if its possible to buy one from you.
Old Feb 10, 2021 | 07:48 AM
  #34
El Chiguete
I'm waiting for that answer too.
Old Jun 6, 2021 | 07:04 AM
  #35
Brickyard's Avatar
Brickyard
Stage I
Default Radial mount for AN 15” rotor
Hi Blue bob new to the forum. are you making these mounts to sell? I’m in Australia and was wondering if you would ship? I assume they would fit a 2018 breakout
Old Aug 28, 2022 | 04:01 PM
  #36
Rob Admiraal's Avatar
Rob Admiraal
2nd Gear
Default BB radial mount
could provide too much brake
This is why I feel the single BB rotor with a radial caliper is plenty of braking for myself. I can almost do a stoppy.
hey Blue Bob. Totally wanna go for your setup..! Looks great; but i cant find a caliper mount to fit a 15” rotor; where you got yours..?
made it yourself perhaps..? It looks better then anything i saw..! Any help would be great
cheers rob a
(info@admiraaltattoo.com)
Old Aug 29, 2022 | 08:52 AM
  #37
Rob Admiraal
2nd Gear
cheers rob a
argh, sorry i found your pics & posts about the fabrication later…Thanks for the inspiration Bob..! Guess i’m gonna make one too then from wood first..!
AJ88V
Jul 27, 2020 03:00 PM
leafman60
May 10, 2019 02:28 PM
Rusty19MCSFV
Feb 27, 2019 07:12 AM
NuckaMan
Dyna Parts
Oct 15, 2016 06:39 PM
71 shovelhead
Jun 25, 2006 10:40 AM
