wind buffeting after adding fairing
When i first fitted it i had it set as close into the bike as it would go. This caused terrible buffeting at anything over 50mph.
I then moved the fairing so it was set in the furthest position from the bike. This improved things a fair bit and was good for up to 70mph.
Now i've moved the fairing about half way back toward the bike on the lower clamps which tilts the screen even futher away from you creating a bigger air pocket. This has improved things further and i'm good up to 80mph.
I'm still tweaking, and next i plan to move the fairing back toward the bike even further on the lower clamps and see if it eliminates the buffeting entirely.
BTW: I'm 5'8" and running the 13" non-vented screen.
I followed what you did and see similar results to yours, slight buffeting starts at 75-80 I am 6' and have the 15" shield with a low rider seat, I might attach a fork bag below fairing to see if that helps push some air as well before continuing to adjust.
