Hey guys so I got the bike all back togeather . But ....yupp always a but with these tedious machines. When I put everything togeather and started it for the first time let it idle for 3 mins and every 10 15 seconds it would sneeze from intake and almost die keep running sneeze and shut off. So I opened carb up thinking that was way too lean and put in witch I was told a starting point of 48/190 but now I've run into a problem I've never seen no matter if I back out the idle screw or close the mix screw she dont choke out . It also seems that the choke half works doesnt kick up as high as it used to I now how v/h shorts and a arlinness stage 1 air on their . I think it might be too rich also if I'm out on it and I'm half open and I get on it prob 3/4 open I feel a sluggish feeling then it goes. No poping on diesel fires right up . Let me know what u guys think thanks 1996 wide glide. With CV carb brand new
For a good primer on modifying your carb visit nightrider.combiketech. There is a dropdown menu on the right side and scroll down to the carb information. Sounds like you're experiencing a leaky carb seal.
That would be amazing cause I just changed it. But who knows guess it's time to break out the starting fluid and look for leaks
I don't know about everyone else, but in my experience the most likely time for leaks to appear is right after installing something... Pinched/upside down/rolled over gasket or seal, etc...
If you took the top off the carb, the rubber diaphragm may have got pinched or not seating in the groove. I've heard of guys putting a little petroleum jelly (Vaseline) on the manifold gasket, seat the intake gasket then a little on the carb and seat it in the gasket.
