Dyna top speed
Old Jul 9, 2007 | 11:50 PM
RazorFXDB's Avatar
RazorFXDB
Default Dyna top speed
The other afternoon I was heading home from a quick jaunt on the bike.
Just to set the scene, I was on a divided highway with no traffic to be seen in either direction. I decided this was as good a time as any to open it up and see what the bike could do. Anyway, the best I could do was 180 kph (112mph). I had the throttle wide open and the speedo just bounced around at 180 kph. I didn't hold it very long, 10 or 15 seconds, but that was as fast as I could get the bike to go.
The bike is stage 1 with V&H short shots and SE air filter.
I'm sure i've seen posts where folks have gone upwards of 120 mph on their bikes. What gives?
Old Jul 9, 2007 | 11:55 PM
SCREAMING EAGLE's Avatar
SCREAMING EAGLE
Default RE: Dyna top speed
ORIGINAL: RazorFXDB
DID YOU HAVE THE S.E. TUNER DOWNLOADED INTO YOUR BIKE AND THEN DYNO'D ?
[IMG]local://upfiles/35788/B7647C1412074B43851308E767E0548B.jpg[/IMG]
Old Jul 9, 2007 | 11:58 PM
RazorFXDB's Avatar
RazorFXDB
The dealer did the download, so I'm assuming it was the screaming eagle download that they did. I don't know if it was dyno'd though. I would guess not.
Old Jul 10, 2007 | 12:00 AM
LowRyder's Avatar
LowRyder
I don't know how fast mine will go yet since the 95 build. But I have bumped into 100MPH as few times and had plenty to spare.
Humm, do you remember the RPMs? I wonder if the rev limiter is set right. It should be with the download but..stock twinkies should do much better than that with the upgrade.
If it was dynoed you would know it. =)
Old Jul 10, 2007 | 12:11 AM
SCREAMING EAGLE
ORIGINAL: RazorFXDB
WELL YOU HAVE TO BUY THE S.E.RACE TUNER KIT $469.00 FROM THEMAND THEN THEY WILL DYNO YOUR BIKE, THE CHANGES I SEE YOU MADE AND ON ANY2006 AND LATER MODEL YOU HAVE TO BUY THE RACE TUNER AND THEN HAVE IT DYNO TUNED , IT MAY SEEM LIKE IT IS RUNNING FINE BUT THE INSIDE'S ARE NOT BECAUSE OF THE EMISSIONS AND 02 SENORS IN YOUR BIKE , I WOULD CHECK MY RECEIPT AND SEE WHAT IT SAYS , YOU CAN HAVE ENGINE DAMAGE WITHOUT HAVING A MAP DOWNLOADED AND DYNO'D !!
[IMG]local://upfiles/35788/B01CAF9F35A247A182B73F6572BA8A09.gif[/IMG]
Old Jul 10, 2007 | 12:12 AM
RazorFXDB's Avatar
RazorFXDB
If I had hit the rev limiter would it not have basically shut the engine down?
Old Jul 10, 2007 | 12:14 AM
RazorFXDB's Avatar
RazorFXDB
ORIGINAL: SCREAMING EAGLE
ORIGINAL: RazorFXDB
I'll check when I get home, but I'm just about positive it was the SE Race Tuner kit I purchased. I'm takin' the bike in this week, so I'll inquire then as well.
Old Jul 10, 2007 | 12:17 AM
SCREAMING EAGLE
ORIGINAL: LowRyder
I HAD A NEW99 LOWRIDER ADDED THE BIG BORE KITAT 350 MILESBROKE MY SPEEDO 3 TIMESIN LIKE 5 YEARS , I HAD THE S.E. REV LIMITER 7,000 RPM ( SAME AS STOCK 1200 SPORTSTER )I SOLD THIS BIKEIN 2005 WITH 8,000 MILESON IT , IT BLEW UP ON THE GUYTHREE WEEKS LATER ,SALE WAS "AS IS " BIKE WAS RUNNING FINE WHEN I SOLD IT !!!
[IMG]local://upfiles/35788/3D9C7BFE9ECD4E4881AF6B6E77DA2B4E.gif[/IMG]
Old Jul 10, 2007 | 12:20 AM
SCREAMING EAGLE
ORIGINAL: RazorFXDB
ORIGINAL: RazorFXDB
THEY HAD TO DYNO IT BECAUSE THAT'S THE ONLY WAY THE DOWNLOAD WOULD WORK CORRECTLY !
[IMG]local://upfiles/35788/5A8EC758E83B4538810157C7AB882637.gif[/IMG]
Old Jul 10, 2007 | 12:25 AM
Crazy03's Avatar
Crazy03
I have done alot of stuff to my bike dynoed 118HP &114 TQ at the wheel, I raced my buddy did 120 MPH slowed only because I have the 10inch T-bars and I dont like being unstable at that speed, I was only in fifth still have way more to go.
