fluids leaking
Old Jul 11, 2007 | 09:25 AM
ML41's Avatar
ML41
2nd Gear
Default fluids leaking
07 SUPERGLIDE WITH NOT EVEN 800 MILE LEAKING FLUIDS THRU THE GASKETS AND OILFILTER WAS TOLD TO MAKE AN APPOINTMENT FOR 1,000 MILE INSPECTION AND THAT THEY ARE FINDING THIS TO BE COMMON AND AFTER THEY TIGHTEN EVERTHING AND CLEAN UP THE BIKE IT SHOULD NOT HAPPEN AGAIN ANY BODY HAVE ANY INPUT IT WOULD BE GREATLY APPRECIATED.
Old Jul 11, 2007 | 09:02 PM
DYNAMITE 1's Avatar
DYNAMITE 1
Default RE: fluids leaking
Gonna go out on a limb here. New harleys dont leak oil, unless somthing is wrong.If your trolling get lost and stop yelling[:@]
Old Jul 11, 2007 | 09:09 PM
Punty's Avatar
Punty
I agree stop yelling. You could check all your toque settings on the drain plugs and oil fliter easy enough.
Old Jul 11, 2007 | 09:23 PM
voyager1's Avatar
voyager1
ML41 Please.cap's off. no need to scream man .
mite be nice if you first tell us who you are,etc,as i see you are a new member with first post . chill down please. take a deep breath. count to 10 . then count to one. repete same steps 3 times .
take back back s.t.a.t to the dealer.
Old Jul 11, 2007 | 09:45 PM
freebyrd's Avatar
freebyrd
got an 07 street bob, same engine as your bike, got about 1400 miles on it and no leaks,
my 01 sporty after about 3000 miles had to have the gaskets on the rocker boxe's replaced, so its not
unheard of for low mile bikes to develope a leak, and that goes for harleys and metrics
Old Jul 11, 2007 | 09:48 PM
Airborne350G's Avatar
Airborne350G
It can happen. Hell on my metric I had a head bolt that was lose and started to leak oil and this was within 500 miles. [:@]So far my Wide glide is running great.
Old Jul 12, 2007 | 01:41 PM
ML41's Avatar
ML41
2nd Gear
Default RE: fluids leaking Thank you
Thank you to all responded and sorry about theyelling appointment made at the dealer to be looked at thanks.
The dealer said this is normal and im not buying it thanks for the confirmation
Ml41
Old Jul 12, 2007 | 02:09 PM
voyager1's Avatar
voyager1
normal !!! call hd customer service. no way is it norm .
Old Jul 12, 2007 | 02:14 PM
07bobber's Avatar
07bobber
i have 3500 miles on my bike and no leaks still havent done my 1k service either. but i def. need to change the fluids.
Old Jul 12, 2007 | 03:05 PM
Marlboro's Avatar
Marlboro
I have a 2006 Wide Glide, I had brought it into the dealer for the trans recall and when I had gotten it back it was leaking on the primary side. Brought it in and the primary gasket was replaced. Then a few days later i noticed a leak again. This time from where the trans couples with the primary. Then again I noticed a leak this time is was from the shifter shaft. Now finally it seems to not be leaking. So you never know. Keep on the dealer until they fix it right. Why pay for parts and change every thing yourself when they will do it for free under the warrenty.
WOLFE1584
Nov 15, 2011 07:49 PM
Steve's Road Glide
Jun 22, 2011 07:27 PM
RKC510
Screamin Eagle CVO Models
37
Sep 11, 2007 09:26 AM
clamiero
Jul 17, 2006 05:00 PM
kman42oo
Dec 19, 2005 09:17 PM
