Tail Light Out, '06 Wide, Not Bulb
Old Jun 27, 2019 | 08:12 PM
PKellyMc's Avatar
PKellyMc
From: PacNW; Beacon of Conservatism in a Sea of Liberals.......AZ Snowbird; Just another Conservative
Default Tail Light Out, '06 Wide, Not Bulb
Hi all;
I've been AWOL from the Forums for a few years now. I have an issue; no running light. Brake light and blinkers are fine, and it's not the bulb. Is there a dedicated fuse for the tail/running light? I'm hoping it's not a bad module. Thanks in advance for any help.
Old Jun 27, 2019 | 09:01 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
Welcome back, nice to hear from you. Have you checked the connections? Might have a dirty pin or socket, disconnect clean with some contact cleaner, re-connect and try again. I read you checked the bulb, bulbs are cheap try a new one, clean the bulb socket also.
Old Jun 28, 2019 | 06:18 AM
Architect's Avatar
Architect
The tire can sometimes rub or contact the wire under the fender, then bad things like this happen. Give a look up under the fender, should be easy to spot. Good luck.
Old Jun 30, 2019 | 02:50 AM
2004DynaRider's Avatar
2004DynaRider
Thumbs up
+1 on This had it happen twice over the years ..
Old Jul 7, 2019 | 09:10 PM
PKellyMc's Avatar
PKellyMc
I'll check for tire-rub (had shortened shocks for a little while), and dirty connections. Thanks to all contributors.
Old Jul 8, 2019 | 05:55 PM
Tumbleweed103's Avatar
Tumbleweed103
Default Check the front brake lever
I don't know if the '06 was like my '14, but mine has a small "button" that must be lined up with and depress a switch within the front brake lever assembly. If you made any adjustments wherein you loosened the brake lever you may not have correctly realigned it when putting it back on. It is very easy to not get it properly aligned and very easy to remedy. Take a close look, or call you H-D Service desk and ask if your model is like mine. I had same problem and it cost me $12 for them to fix it and they explained it to me and now I have fixed my own several times after making adjustments. Good luck.
Old Jul 8, 2019 | 06:32 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
OP: Clarify...
There are running lights on the front, in the turn signals, there is also a running light in the rear, the tail light.
Are all running lights inoperative?
Old Jul 8, 2019 | 06:39 PM
Dan89FLSTC's Avatar
Dan89FLSTC
The OP is not having a problem with the Brake Light...
Old Jul 8, 2019 | 06:56 PM
Tumbleweed103
Ok. My misread. Never mind.
squaco
Electrical/Lighting/Alarm
Jun 13, 2015 02:18 PM
hamdizle
Jun 27, 2013 10:44 AM
IBADB
Aug 16, 2012 01:14 PM
klf33
Jun 23, 2009 10:39 AM
MidWest XL
Feb 2, 2005 10:40 PM
