Need some wiring help
Old Jan 28, 2020 | 08:51 AM
snake_eyes's Avatar
snake_eyes
Default Need some wiring help
I'm installing the turn signal relocation kit on my '17 FXDB and I need to crimp some connectors. I've never had any luck with this style of pin so I'm looking for some help. What type of crimper do I need? Is this a Molex pin? Can you guess a size off the pic with the beer can? This is for the 3 wire turn signal connectors.
Old Jan 28, 2020 | 09:08 AM
Harleylife1's Avatar
Harleylife1
pretty sure its a molex. as for everything else not so sure sorry. good luck!
Old Jan 28, 2020 | 09:21 AM
Jay Guild's Avatar
Jay Guild
Yup, those are Molex.
Old Jan 28, 2020 | 10:14 AM
FXD2003Rider's Avatar
FXD2003Rider
Administrator Emeritus
Check out this post by mud for his home made crimping tool...
Old Jan 28, 2020 | 07:11 PM
multihdrdr's Avatar
multihdrdr
Actually, those look to be AMP / Tyco / TE Connectivity "Multilock" Connector Terminals ... Not Molex (Brand)
Old Jan 29, 2020 | 08:42 AM
snake_eyes's Avatar
snake_eyes
Can i use the same kind of crimper?
Old Jan 30, 2020 | 11:30 AM
GearheadMike's Avatar
GearheadMike
Granted this is only turn signals, but I would solder them.
Old Jan 30, 2020 | 11:43 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
It`s a crimp connector, obviously it is designed to be crimped. Solder is not the way to install this connector.
You will never see a solder joint on an OEM connector. A proper crimp is the best way to install a terminal to a wire.
Old Jan 30, 2020 | 11:45 AM
TriGeezer's Avatar
TriGeezer
I’m making some harnesses, and bought this on Amazon, and it works well. I’d use this rather than any other option that will scru it up, There’s a reason Harley selected Molex, which are the best you can get. Don’t scru up your reliability by cheaping out for $20,
IWISS Open Barrel Terminal Crimper Plier Tool for Molex Style DELPHI AMP TYCO Terminals Crimper Open Barrel 24-14 AWG
Amazon Amazon
BTW, if I was to buy a used car or motorcycle and saw that someone made hack job electrical modifications, I’d stay clear.
Old Jan 30, 2020 | 12:14 PM
mud's Avatar
mud
IWISS Open Barrel Terminal Crimper Plier Tool for Molex Style DELPHI AMP TYCO Terminals Crimper Open Barrel 24-14 AWG https://www.amazon.com/dp/B07476C1LD..._YxXmEbM27WBJV
If I was wiring every day I would want that $35 one.
That $17 one looks like it works fine.
