engine cutting out when hot
Old Feb 16, 2020 | 04:38 PM
Pascal Westrich's Avatar
Pascal Westrich
4th Gear
Default engine cutting out when hot
Hello, I read a lot in this forum and already took some advice in checking out different things. Here my problem, the bike is running great when cold for about 10 miles. After this, the engine is cutting out and will not start until engine is cold again. Its not turning over at all, the fuel pump and starter not getting power and when i hit the run /start switch nothing is happening. The bike is cutting out like somebody is hitting the stop switch. On my last visit to the dealer (260 miles away), he put it on the scan and could not find anything. There is no fault code so far. the bike was running great for about a year (14000 miles) and now it is starting to act.
2008 FXDF Fat Bob
Stage 1 upgrade
changed so far:
MAP
STARTER RELAY
SYSTEM RELAY
CRANK POSITION SENSOR (CKP)
SPARK PLUGS
CABLES
IGNITION COIL
CLEANED ALL CONNECTORS AND CHANGED ALL FUSES
TESTED TEMP SENSOR BUT SEEMS TO BE OK( ANYWAY ORDERED A NEW ONE)
now i am tending to the immobilizer. Any ideas or input would be highly appreciated.
Best regards
pascal
Old Feb 17, 2020 | 05:00 AM
joe40x's Avatar
joe40x
It sounds like you have covered about every thing.
Could be the ignition switch or a short in the handlebar wiring.
Old Feb 17, 2020 | 09:29 AM
Pascal Westrich
4th Gear
Hey Joe
Thank you very much, I will check this today.
Best regards
Pascal
Old Feb 18, 2020 | 08:37 AM
Jeremey8025's Avatar
Jeremey8025
I was having a similar problem with my '13 Super Glide a few months back and checked a lot of the same things you did. Turned out is was my battery connection at the negative terminal.
It was plenty tight when I would check it, but if I disconnected it and then reconnected it, the bike would have power again. I cleaned up the terminals then added dialectic grease and a lock washer to the connection and have been trouble free since. Not sure if it's what's happening for you, but it's easy to try. Good luck.
Old Feb 18, 2020 | 12:36 PM
Pascal Westrich
4th Gear
Hi Jeremey
Thank you very much for your advice, checked this already. Turns out Joe was right. I disassembled the handlebar and after testing the switches i found the run switch only made sometimes contact. A new one is on the way and i hope the problem will be resolved.
Old Feb 19, 2020 | 10:17 AM
Oldskewl's Avatar
Oldskewl
02 sensors.
Igoinxs
Milwaukee Eight (M8)
Nov 12, 2018 03:59 PM
mvoss76
Aug 31, 2017 08:46 AM
captjon37
Apr 10, 2010 04:48 AM
Sandy Mike
Oct 1, 2009 09:42 PM
Stretchman
Nov 30, 2008 07:53 PM
