Appliance epoxy
Old Feb 29, 2020 | 01:32 AM
Matthew Kisor's Avatar
Matthew Kisor
Default Appliance epoxy
Hey all, I’ve seen a few posts about using appliance epoxy to black out different parts but I haven’t seen much about using it on chrome. Does it work pretty well? Also should I prep it the same? 220 grit and metal etching primer?
Old Feb 29, 2020 | 08:15 AM
cggorman's Avatar
cggorman
It works fine on solid (not peeling/flaking), scuffed chrome.
Scuff to 220-320, but chrome is pretty tough. Be patient and meticulous.
Etching primer, yes.
Depending on desired finish, you may also want to add a sanding primer stage with additional sanding refinement to 600 grit.
As always, prep is key. Remove all wax/grease/oil prior to first sanding (to keep it from getting ground into the underlying metal) then remove all dust and hand oils prior to each paint layer.
Rattle can epoxy takes a long time to cure. Allow a week at room temp before installing.
Old Mar 1, 2020 | 10:17 AM
shiftace's Avatar
shiftace
I just did my lowers yesterday. I had one 20yr old cruddy and one brand new lower. I used 220 grit and knocked both down til all the factory clear was gone, tedious but you have to get all the nooks and crannies. Masked off the tubes and cleaned everything with alcohol (and drank a little alcohol) I read an older thread on here about having exactly 30 minutes to do all your coats before the paint set up too much so I set myself a timer. I did 5 light coats over 30 mins and let em sit in the house all night. Now, I cannot paint a damn fingernail so my paint projects usually turn out horrific but I’m actually super stoked on how these look. Pics don’t do justice in the garage so I’ll take some outside later on. Give yourself plenty of prep time, work super clean and this paint is pretty forgiving if you just do light coats. It’s heavier than normal paint so it’ll run quick if you shoot it on too heavy.
Old Mar 1, 2020 | 10:49 AM
Matthew Kisor
they look great man!
Old Mar 1, 2020 | 11:30 AM
shiftace's Avatar
shiftace
Mounted up with my new calipers.
Old Mar 1, 2020 | 11:43 AM
Matthew Kisor
looks like powder, awesome job!
Old Mar 1, 2020 | 03:46 PM
shiftace's Avatar
shiftace
I’m happy with it. I bought the bottle of touch up too for chips.
Old Mar 1, 2020 | 04:12 PM
Crazy's Avatar
Crazy
Nice work.
enigmah
Powdercoat & Paint
Feb 25, 2020 11:05 AM
oct1949
Jan 28, 2010 12:42 AM
Badbagger
Sep 2, 2009 11:18 PM
millersbobber
Mar 6, 2009 01:44 AM
In Memoriam Citoriplus
Feb 13, 2008 05:51 AM
