Evo or not?
Old Jun 6, 2020 | 11:38 AM
Rchilton's Avatar
Rchilton
Originally Posted by FreedomRider
the chrome oil filter for an EVO is 63796-77A ... not sure about the number for the black one ... your bike is an EVO ... and it is a V2, the V2 refers to the ignition timing system on the bike ... the V2 is the better system ... in an EVO most find it better to run 20w50 in the engine ... tranny and primary can run the same fluid, Formula + is a good choice ... do not fill the engine oil to the full mark on the stick, it will weep oil through the air cleaner unless an external breather has been installed ... you can get a lot of good information in the EVO section
Yeah I've had oil get pushed through the breather before on my old VStar 1100.
I like external breathers but they interfere with my ability to brake with forward controls.
I've got one on the Sportster and I had to put an extra long brake pedal on it because of the interference.
Old Jun 6, 2020 | 11:40 AM
Rchilton's Avatar
Rchilton
Originally Posted by truckerdave
Looks like it's been sitting for a while. Couldn't hurt to check the date codes on the tires. They might be 20 years old.
Tires were just put on last year. Never been ridden since.
Old Jun 6, 2020 | 11:42 AM
Rchilton's Avatar
Rchilton
I would love to have that bike, gorgeous, clean and polish it up, what a find! I'm drooling
I swear, from that angle, that looks like a car tire on the rear.
That's what I thought when I saw the first pics. But no they're motorcycle tires.
Matched set front and rear.
Old Jun 6, 2020 | 11:56 AM
Rchilton's Avatar
Rchilton
Here's a better pic. It's only got 12,000 miles on it. Just ordered $2100 worth of parts and accessories yesterday. Windshield, Engine guards Shifter/ Peg,l brake pedal Already installed. All lubes / filter, Grips / throttle lock, Head light upgrade ,Signal lights. Saddle bags H.M. ,Luggage rack And miscellaneous other maintenance stuff.
Old Jun 6, 2020 | 12:06 PM
Rchilton's Avatar
Rchilton
The oil pan drain was stripped. Actually the transmissionl drain.
Apparently some one used a helicoil for the repair
That's usually a one time fix and not permanent
There was basically very little thread left
So I drilled and tapped 1/64th larger and found a 5 x 20 O.S. plug.
Worked perfectly. But I ordered a new oil pan anyway for next oil change.
Old Jun 6, 2020 | 12:16 PM
King Nothing's Avatar
King Nothing
I love a good EVO and what a gorgeous bike to boot!
Old Jun 6, 2020 | 02:31 PM
multihdrdr's Avatar
multihdrdr
https://shinkotireusa.com/product/su...70-tire/211905
Joedirt69
EVO
21
Dec 20, 2022 06:22 AM
john lee
Shovelhead
11
Apr 19, 2020 05:03 PM
upland117
EVO
18
Jul 19, 2014 10:19 PM
nh-dwg
EVO
Jan 19, 2012 04:31 PM
evofloyd
EVO
24
Feb 27, 2011 09:10 PM
