Fxdls handlebar internal wiring
Old Jul 13, 2020 | 06:54 AM
charles8606's Avatar
charles8606
Default Fxdls handlebar internal wiring
Im changing my stock bars for these bars, 30 in wide 12 in high, will my stock internal wires will be long enough since the stock bars are 36 in and have a little loose in the wires?
thx
Old Jul 14, 2020 | 01:19 AM
SoCal_FXDLS's Avatar
SoCal_FXDLS
You should be good, there is a TON of extra length of the handlebar wires crammed into the neck of the frame. I went just about 13 inches up on my riser/bar combo and had tons to spare.
Old Jul 14, 2020 | 07:18 AM
Suede Blue Man's Avatar
Suede Blue Man
Go out and remove the rubber neck plugs and gently start pulling out the control wires from both sides, you'll find you have about 84 million miles of wire! I have never read here on the forum where anyone had to extend control wires, now your clutch cable and brake lines are a different matter.
Nice bars
Old Jul 15, 2020 | 08:16 PM
charles8606
Thx man, went with magnum cables, upper abs +6, clutch+6 and lower stock length
Hrdhtdvr
Sep 29, 2012 11:52 AM
Jaystn62
Nov 14, 2011 02:24 PM
armyglide
Oct 2, 2011 09:00 AM
mstng5point0
Jan 26, 2009 07:34 AM
Brian
Oct 27, 2005 09:46 PM
