Feedback on converting to chain drive with a S&S 124 motor
Old Aug 25, 2020 | 01:19 AM
cycler's Avatar
cycler
Default Feedback on converting to chain drive with a S&S 124 motor
Can I get some feedback on pros and cons to converting from a belt drive to chain drive if installing a 124 motor into a Dyna? Or is that one of the 1st things that should be done if installing a large displacement motor like that?
Old Aug 25, 2020 | 08:29 AM
TexasScooterTrash's Avatar
TexasScooterTrash
Belt drive was one of the best innovations to come along. Pretty much maintenance free, clean and quiet. Chain drive is regular maintenance (chain stretch,) regular lube, regular clean off all the lube thrown off the chain and noise. An S&S 124 should be just fine with the belt unless yer gonna be doing wheelies and burnout.
Old Aug 26, 2020 | 12:16 AM
M4dm4x's Avatar
M4dm4x
I have a 124 making 142/143 in my street bob, belt held up fine even doing wheelies. Talked to some builders and they said they worry more about spokes than belts. I have since converted to chain tho, in order to run some wheels off a Sportbike.
Old Aug 26, 2020 | 01:14 AM
cycler's Avatar
cycler
I wont be doing any wheelies or burnouts. Ive been tracking and competing on sport bike since I was 9 years old and have never done wheelies or burnouts. I was more scared of dumping the bike while doing a wheelie than actually crashing the bike. I can tell you right now that in all my years of riding Ive done 3 burnouts. Well no wheelies because my mother would say in her Russian accent. "You do veelie end crash zeh bike end me and poppa cryash on yoor head. Eef you do boornout and mess tyire op you vill be in beeg trobble. You heer me and undoorstyand?
Old Aug 26, 2020 | 05:58 AM
98hotrodfatboy's Avatar
98hotrodfatboy
The smart thing would be to try the belts before you switch anything over.. You have nothing to lose.. The most important thing is having a proper belt tension though.. It should handle it no problem I know a lot of people that are running big motors and still belts..
Old Aug 26, 2020 | 06:07 AM
Iceman24's Avatar
Iceman24
Belt drive + belts last forever...chain drives are messy, more maint, stretch & break easier. Until you posted this questions, I almost forgot about the old days of oiling, linking, fixing & tightening. Don't miss it...>.<
Old Aug 27, 2020 | 11:54 PM
cycler's Avatar
cycler
Yes youre right about keeping the belt and seeing how it holds up first before to a chain drive.
Old Aug 28, 2020 | 12:53 AM
cycler's Avatar
cycler
Right now Im running the numbers on 3 scenarios to see what the costs are. Then to see whether a brand new S&S 124 with the additional components and 2 year warranty is worth buying instead of building a 110 motor without having to spit the case open to install a Timken bearing and do crank work. The cost wont be horrible since Im getting everything at dealer price from my MC bro. So far the cost difference between the S&S 124 with extra components and 110 build with extra components is between $2500-$2750. This is after I sell my 107. So I need to decide whether that cost difference is worth it with a 2 year warranty and a difference of what? 10-13hp and 7-10 ft lbs of torque
I
Old Aug 28, 2020 | 03:19 PM
cggorman's Avatar
cggorman
Several years ago when I was researching my own chain conversion, very few 530 roller chains were recommended for even stock Big Twins (say, 110" down). No experience myself, but for a 124 I'd guess you're pretty much asking for chain/sprocket failure with anything smaller than a 630 if you plan to actually hook up that power to the ground.
Either way, I'd strongly suggest speaking with a few of the top chain and/or sprocket manufacturers to see what they have to say about sizing.
Old Aug 28, 2020 | 05:01 PM
Bob_fxdb's Avatar
Bob_fxdb
Chain doesn’t stretch, the holes on the joints gets bigger and that would literally take an eternity before it does, and that is when your chain is not adjusted correctly.
Belt drive is not the best innovations to be honest. Especially not on harley’s when the primary case covering the front sprocket. It’s a lot of work to replace a failed belt vs a failed chain. If your motor is already out I would convert it to chain right away.
I know belts are strong but not stronger then chain, I also know that belts are convenient but not so convenient when your belt snaps and you’re left stranded on the side of the road. You would be safe with chain. I wouldn’t trust a belt with 124". Clean and lube it when you’re washing your bike, it literally takes 5 minutes extra lol
