Speedometer issue 2007 FXD
I was wondering if anyone could help me track down this issue Im having with my speedometer.
I noticed that my speedometer wasnt working on my way to fill gas. Turn signals and neutral indicator work.
i figure that theres a poor connection somewhere because the speedometer works when the bars are at full turn either way.
it blanks out when the bars are straight.
WHen I move a particular set of wires, the speedometer works.
Im trying to find out how to access this wire bundle to check for shorts or damage.
Would this involve removing the tank?
I just picked up this bike, so its new to me.
Any advice appreciated,
It may take time but you will find it. Have the bars been changed . Did person you got it from remove anything and maybe part stock parts back on ?
I got the bike like this. It has aftermarket bars, and I believe they were swapped a while ago.
Funny thing is that everything worked until today when I wen for gas and noticed the speedo wasn't working.
After I got home, I traced the potential problem to a bundle of wires going into the frame from the speedo on the port (left) side.
With the ignition on, I would turn the bars from full left to full right. At full left and right, the speedo worked. With the bars centered, the speedo cut out.
With the bars centered, I moved the aforementioned wire bundle, and the speedo would flicker off and on.
I don't know where that bundle terminates once it goes into the frame. Somewhere under the seat, I figure.
If there's a connector somewhere in that run, it may have worked loose.
It looks to me that the only way to get to those wires is to pull the tank. (I literally just filled it....)
Thanks for the advice.
I tried prying on those plastic plugs, but I wasn't sure if they were meant to be removed. I'll try them again.
The speedo is still attached to the bar clamp. I can see a connector that *appears* to be the one connected to the speedo through the hole in the frame.
I'll check out that blanking cover you mentioned, as well.
Thank you!
Looks like I have to remove those grommets from both sides of the frame, and that cover above the front cylinder.
Like I mentioned earlier, I believe I have isolated the issue to one particular wire bundle. When I move this bundle directly, I can get the speedo to power on and off.
Maybe I'll find a connector of some sort not fully engaged.<crosses fingers>
Thanks for the advice on the tank, Harleywashboy. I may have to do this soon.
Remove the rubber plug on the neck. Brake side.
Remove front gas tank bolt and carefully place a short 2x4 under the tank for clearance wrapped in a cloth to prevent scratch’s. Remove the plastic cover under the tank and pull the cluster out.
Unplug the harness on the brake side and feed up through neck where you removed rubber plug.
once you get the wires pulled out of the neck plug back in and turn on key and you should be able wiggle each wire and determine where your break is.
Previous owner probably extended the wires and there is a faulty solder or connection on one of the 6 or 8 wires. Some of the extension kits are crimp (no solder). Make sure and solder all connections.
For clarification, my bars are not stock. They are also internally wired.
Forgive me if I'm wrong, but it doesn't appear to me that any of the wiring going to the speedometer goes through the handlebars at any point.
I have a FXD, so my speedo is mounted directly to the handlebar clamp.
The "suspect" wire bundle that I mentioned earlier goes through the frame on the clutch side.
At any rate, I'll have to lift the tank to see where this bundle goes and get some more accessibility.
I agree that it's most likely a short or failed connection somewhere in that wiring run.
Thanks again for all the help! I'll update this once I start up again.
