Fat Cat vs LSR
That does look good. How do you like the sound? Is it ever TOO MUCH?
I've heard comments before about Fat Cats being that loud, but every video I've watched, I love the boom-y-ness of it. The deep tone to it. I think the D&D kinda states about a certain one for certain engine mods and up to a Stage 3, then another one for Stage 4+. I'm still undecided if I want to do a Stage 4 or just stick with a Stage 3 103ci and up the compression and put better heads on it. I want to see if I can hit 110-115whp with a 103ci. I've seen it done before. I think it'd be FUN. Haha. I already have the intake. The ONLY choke point then, would be the factory heads, but I've been looking at FM head upgrades as well. I've looked at all of it already. So many decisions. Maybe talk to Woods, figure out a cam grind, and get THEIR opinions on exhausts and heads. I'm sure they know a thing or two about what good combos work together and what don't. Thanks for info!!
Maybe you can get some idea of the tone, but even that will change with the volume relative to how close you are.
Go to any bike event and listen to pipes first hand, that’s the only way to realistically hear how “loud” a pipe is.
As an example, go find Matt Laidlaw’s exhaust comparison video. You’ll hear a dozen pipes, and even the stock pipes sound pretty much as loud as the D&D he has (maybe with less clipping) because the levels are all boosted/lowered to match what the camera thinks it should be.
All that said, I had a fat cat on a M8 Softail with a cam, and it was f’n loud. I never heard a twin cam, but I understand they are louder. I would love one on my worked LRS, but now that I’m in Florida, I don’t want to get shot at by the neighbors...
And Mchad is right.. You need to go to an event to listen to these things to get an honest opinion.. the real key though too a good sounding pipe is compression..
Here's a sounds bite with the RB LSR pipe..
A shop I know recommended against Fat Cats on Dynas. Said they saw a number of head pipes cracking from the vibration. Dont really get that, as the bracket mounts to the transmission, which of course is bolted to the motor, making the entire setup effectively one piece. The Fat Cat is big, maybe the trans bracket flexes a little too much putting stress on the pipe? Dont know the answer to that though.
The one I had on a Softail was very solid (well built) - I would still probably get one for my Dyna. Wish I could hear the volume of it with my mods. I like loud, but not ear bleedingly so. The M8 Fat Cat was loud indeed, but M8s are so different exhaust sound wise, its comparing apples to oranges...
