Seized rear Fender bolt snapped extractor
Old Jan 22, 2021 | 04:07 PM
gros21's Avatar
gros21
Default Seized rear Fender bolt snapped extractor
Well I've got a fld and I'm. Trying to remove my fender bolts I removed 3 of 4 but 1 stripped out so I went and bought a good screw extractor which is now snapped in the hole. What's plan b?
I cant drill out the extractor as it's hardened. Do I grind the the top/bottom off the nut to try to get a spanner on it do I grind a big slit in the bolt to use a screwdriver.
Old Jan 22, 2021 | 09:21 PM
Blue Bob's Avatar
Blue Bob
Pictures please
Old Jan 22, 2021 | 09:45 PM
im's Avatar
im
It is best to provide basic information in order to provide a possible solution.
For example:
Exact motorcycle- It seems like you might have a dyna
What year?
Perhaps something like this link could better assist with exact part number?
http://partsfinder.onlinemicrofiche.....asp?make=hdmc
Old Jan 22, 2021 | 10:46 PM
gros21's Avatar
gros21
Got it out after 3 or 4 hrs of non stop work stated spent 5hrs on the bike today working.
Easy out was hardend steel plus the heads of the bolts are sunk into the washer/spacer for orginal saddlebags. Spent hrs grinding that away with a dremel then cut a 2 flat sides so a set of vice grips could bite in. I suspect the dremel created a fair bit of heat that helped.
I've mounted the new saddlebag brackets now having a rest then will mount new sport glide bags on.
Plus I mounted and wired the reckless fairing today 🤟
Driveway is a mess but that's tomorrow's issue.
Old Jan 22, 2021 | 11:30 PM
Ricky2Guns's Avatar
Ricky2Guns
Been there, I know what you mean but it feels good to overcome the obstacle at the end of it all.
kountry
Mar 1, 2015 10:58 AM
Dannyrider
Sep 21, 2014 04:15 AM
Dynamo27
General Topics/Tech Tips
Jun 13, 2014 04:28 PM
DirtyThirty
Mar 20, 2011 09:49 PM
thedodge
Oct 13, 2008 09:47 AM
