Always a lot of talk on here about compensators and solid motorsprockets or the Darkhorse setup. I follow George on youtube and am also a big fan on his parts. A lot of great info here for those that don't know of him.
$400 for the ramp? You can buy a whole comp for $200 without springs. How many have broken the stock one? I know some of the bigger motors are breaking them but why not shot peen and magnaflux a new one?
That $400 ramp is for the M8, which is weak from the factory and breaks. He clearly stated the TC comps don't break.
For a good piece of steel, machining, hardening, polishing, etc., $400 is not a bad price, especially if it solves a problem.
Although I agree with what the guys saying, I don't agree with a $400 ramp. The SE comp for my TC is just fine...
He stated the SE comp is good. He ran 9.3 and 9.4 in a Bagger with 190-200 hp NA for two years with one.
Although there is guys I'm sure that swear by a solid motor sprocket, he explained very well why one should not go to one. I like how he explained also about changing the primary ratio is also a bad idea.
When building up my motor, I did speak to my builder about all these things, and even with 150 hp, he recommended staying with all the stock components and just adding the AIM VP-SDR to the clutch. Mind you, the Low Rider S came with the SE A&S (3 Studs Style) clutch, instead of the Non Slipper (6 stud style) clutch found on the rest of the Dyna line. You can still get the upgraded SE A&S clutch from Harley for $400 bucks. It's rated to 135 ft lbs and adding the AIM, it's holding 145 lbs with a 124" (with a stock basket) on mine.
While some guys may have grenaded the stock clutch basket, clutch, etc., I have seen where individuals removing the stock parts damaged them upon disassembly by not using the correct tools and methods, and then those parts failing later.
I had to swap one on a ‘12 street glide with 20k on it before I totaled it, but I’m at 50k on the one in my ‘15 Roadie. I think a large part of the wear is what fluid your running and how you ride. I bought the ‘12 used with 10k on it, and the ‘15 new. On the ‘15 I’ve only ever run Redline in, and I ride 75 miles a day partially in stop and go traffic. The ‘15 is due for a swap, but with other things to deal with (getting my ‘99 DX road-worthy) it can wait for a bit, especially since I need to tear the front end down anyway.
