fork lock not working
Old Aug 7, 2007 | 10:57 PM
nkauf21's Avatar
nkauf21
Default fork lock not working
I guess it must have gotten out of adjustment somehow. Any tricks to get it working again, or should i take it to the dealer.
Old Aug 7, 2007 | 11:02 PM
mud's Avatar
mud
Default RE: fork lock not working
ORIGINAL: nkauf21
Do a search nk.
There was a lot of discussion about this a year or so ago.
If I remember correctly, the solution was as simple
as reaching up from underneath with a screwdriver.
Look it up. I may be wrong about the screwdriver (alignment issue).
mud
Punky Brewster's Avatar
Punky Brewster
ORIGINAL: nkauf21
Seems to be a problem with the newer bikes,take her back to the dealer.
Old Aug 7, 2007 | 11:36 PM
mjdodd1107's Avatar
mjdodd1107
No need for the dealer on that one.
Just as mud described, use a screw driver to realign the pin that drops down from right underneath where the key goes
Old Aug 8, 2007 | 12:19 AM
nkauf21's Avatar
nkauf21
cool, thanks guys
Old Aug 8, 2007 | 06:50 PM
simsjam's Avatar
simsjam
I had the same problem on my 2006 FXDI. I used a screwdriver to nudge it back to the proper position then I cut a short piece of fuel hose and wedged it in the space to keep it from moving out of position again.
Old Aug 8, 2007 | 08:07 PM
six8olds's Avatar
six8olds
I had the same problem too. So what I did was take the front forks off and dance around them chanting for a little while. . . It didn't work. [:@]
But seriously, I don't know what i would do if I hadn't found this forum. Y'all have saved my butt from the dealer more times than I can count. Thanks!!
Old Aug 8, 2007 | 08:20 PM
cardboard's Avatar
cardboard
Go to Academy or where ever and git some Remington Rem lube, Its a Teflon spray . If you could find Tri Flow its better. Put the plastic nossle in it and spray it in the keyhole. The locks needs to be lubricated every now and then or they git dry from water, heat, Humidity,and dirt.
It might help. I've used to try to show folks to lub their locks when I had a business.
Old Aug 8, 2007 | 10:00 PM
Bobber S's Avatar
Bobber S
Mud is right with the screwdriver thing. All above is great advice thanks again to the users & operators of the form. I had the same issue and this saved methe inconvience ofa would bewasted trip to the dealer.HD should be ashamed of themselvesputting such piece of crap ignition tumblersonexpensivebikes.
Old Aug 8, 2007 | 10:03 PM
Trotter's Avatar
Trotter
Yea but if you take care of it, It'll out live you....
ORIGINAL: Bobber S
