ECU error when riding 2up
Old Jun 28, 2023 | 09:17 AM
fordaith's Avatar
fordaith
Default ECU error when riding 2up
I have a 2016 Low Rider S, and it seems like every time I ride two-up, I get an issue with the speedometer cutting out, a bunch of error lights and then a speedo sweep. I've tried tightening the battery posts, and I know the battery is fine because it's brand new.
Is there a weight sensor or angle indicator that could be tripping causing the issues or what else could I be looking at?
Old Jun 28, 2023 | 09:22 AM
2500hdon37s's Avatar
2500hdon37s
What are the codes you're getting?
To me it sounds like a loose wire or something getting pulled or pushed enough to lose connection when the weight of a passenger is on your bike. Does the bike stay running like normal when it happens?
Old Jun 28, 2023 | 10:23 AM
fordaith's Avatar
fordaith
Yeah, it runs fine, and it's only the speedo, because all my ECU signals are good because everything works perfectly on my power vision.
Old Jun 28, 2023 | 11:33 AM
nevil's Avatar
nevil
When you tightened the battery posts did you also check the other ends of the cables?
Old Jun 28, 2023 | 12:01 PM
im's Avatar
im
Do you have a wire loom under rear fender that has scrubbed tire?
Old Jun 30, 2023 | 04:00 PM
Jackie Paper's Avatar
Jackie Paper
Community Influencer
Just how heavy is your rider for you to ask that?. Better not let her see that text.
Make sure your speedometer plug is reset.
Old Jun 30, 2023 | 10:20 PM
Max Headflow's Avatar
Max Headflow
I would put money on something screwing up the CAN bus. You'll need to extract codes.. If on the speedo has issues, it's likely between the ECU / BCM and the Speedo.
Add:
Maybe a pinched wire under the seat?
Rodent66
Electrical/Lighting/Alarm
May 21, 2024 05:27 PM
TormentedH-D
Jul 19, 2014 11:18 AM
mbac
14
Oct 10, 2012 06:58 AM
tonedef
Jul 15, 2011 06:01 AM
grubby
Feb 25, 2009 11:13 PM
