01 dyna cutting out
Old Oct 5, 2023 | 07:41 PM
SSBMX's Avatar
SSBMX
Default 01 dyna cutting out
(2001 wide glide 88 twin cam carburetor) Long story short I got my gas tank media blasted and the ******** must not have covered all the holes because when I received it back it was full of media blast. I cleaned the tank out multiple times put a new petcock filter in and an in-line fuel filter. It was going good for a long time. Just would change the in-line filter once in a while. Now all of a sudden at random times the bike will slowly bog down and shut off. Sometimes if I wake the throttle it’ll be fine but eventually it dies. I don’t think it’s anything electrical. Does anyone have a good way to fully filter this gas tank out? It’s driving me nuts.
Old Oct 6, 2023 | 07:21 AM
TexasScooterTrash's Avatar
TexasScooterTrash
Sounds like it Keihin rebuild time.
Old Oct 6, 2023 | 12:22 PM
John CC's Avatar
John CC
If the in-line filter is still collecting junk then I'd suspect the screen on the petcock.
Old Oct 6, 2023 | 12:24 PM
hattitude's Avatar
hattitude
Do you still have the OEM Vacuum petcock? If so it may have been compromised by the debris.....
When you had the tank media blasted, did they get all the old liner off? Did you reline the interior of the tank? It wouldn't be the first case I've heard of a tank being relined and the new liner material failing quickly... That's why I left mine bare after the OEM liner peeled and I removed it...
In any case, sounds like it's time to check the tank again for debris, and disassemble the vacuum petcock and/or the carb for a good cleaning/rebuild... Luckily, both are pretty easy to do...
Let us know what you find...
t34418l3-1
Aug 14, 2012 06:52 PM
hutchjh828
May 4, 2012 01:06 PM
stbobshadow
Nov 22, 2011 11:12 AM
Hoggin
Exhaust System Topics
Mar 29, 2007 12:11 AM
vernh59
Jan 11, 2006 03:39 PM
