Backrest Side Plate Compatibility
Old Dec 14, 2023 | 08:03 AM
ThePaintPirate's Avatar
ThePaintPirate
Default Backrest Side Plate Compatibility
Been browsing ebay and looking through HD P&A catalogs for over a month to get an idea on what side plates work with my 03 Low Rider. There's a mind boggling array of shapes, cutouts, number of holes and straight/bent; and of course no part numbers on the brackets. To make things more complicated, I've got the Wide Glide rear fender (which I still want to replace with the correct fender) but at least the previous owner put on the quick detach and turn signal relocation kits, and the catalog says there's different plates for a Wide Glide. A few searches on the site references that I can use plates from 96-05 or even plates from Sportsters. I'm sure this is a road that many have been down before, so what say the hive mind for both rigid mount and quick detach?
Old Dec 15, 2023 | 03:12 PM
Arseclown's Avatar
Arseclown
I was trying to find some information on side plate interchangeability too but it’s hard to find
Im pretty sure sportster side plates won’t work. The length that bolts on to the fender, or attaches to the docking points, is a different length to the dyna
Old Dec 17, 2023 | 10:03 AM
08xl1200r's Avatar
08xl1200r
Yep, that is correct, I just learned that by trying my '07 Sportster plates on my new to me '98 Dyna, the Dyna bobbins are further apart.
Old Dec 18, 2023 | 04:44 AM
eighteight's Avatar
eighteight
File Type: pdf
Old Dec 21, 2023 | 07:39 PM
ThePaintPirate
Threw the dice and picked up a set that fits, but now trying to figure out the QD setup, everything I can find uses the turn signal stalk as the rear docking point and it's beveled to fit the plastic sheath, but of course mine isn't.
djcouple
Mar 25, 2014 10:52 AM
HDexplorer
Mar 12, 2014 10:57 AM
bellarosa
Apr 2, 2012 10:07 PM
1HD1C
Jun 7, 2011 10:30 AM
waterman7474
Jun 20, 2007 07:58 PM
