2013 fxdf LED Issues
Old Dec 31, 2023 | 10:15 PM
MyFatBob's Avatar
MyFatBob
Default 2013 fxdf LED Issues
Changed 2013 FXDF Fat Bob incandescent turn signal & Running lights to(Eagle Lights) LED’s. I’m having issues, All turn signals & running lights are operating normally. Here’s the issue on the dash Signals flash correctly for 2 flashes then go rapidly. Bike keeps throwing codes LT & RT Turn signals circuit open, HD has replaced the ECM & BCM, No change. A few day’s ago they connected it to the Digital Tech and changed a BCM setting. Said it would take a while for BCM to learn the LED’s. Several rides later No change, I have tried multiple methods of correcting it. HD said said bike should not need any sort of resistor’s or equalizers due to it having a BCM. If anyone takes the time to read this entire message I appreciate it, Thank you. Any suggestions are very welcome, I’m just frustrated with problem been dealing with it for 1 year, Ughhhhh. do you think I can still add the equalizer, Without toasting anything?
Old Jan 1, 2024 | 01:09 PM
Czracer's Avatar
Czracer
Might have to get a load equalizer. I had to get one for my 2008 FatBob. It plugs right into harness .
Old Jan 1, 2024 | 02:19 PM
Addicted to Chaos's Avatar
Addicted to Chaos
IIRC, 2012 and after Dynas are CANBUS. 2008 needed a LE but your 2013 shouldn't.
Some have had success with this:
Old Jan 14, 2024 | 04:46 PM
MyFatBob's Avatar
MyFatBob
Eagle Lights sent me Gen2 Front turn & Running lights replacing my Gen 1. Instant fix, Finally
MyFatBob
Electrical/Lighting/Alarm
Jan 2, 2024 06:24 PM
PEESKI
Dec 31, 2023 10:49 PM
03nighttrain
2014-2024 Touring Models
11
Apr 25, 2018 01:34 PM
mtnroadking
Mar 17, 2013 03:19 PM
rossdog
Jan 9, 2013 12:08 PM
