New Heads and Cam...
With the valves seated what is the distance between the edges of the 2 valves?
It's a Tman cam?
[Edit] Is the bolt in the upper left of the photo loose? How did that happen? Is that the valve that stuck?
Did you have any backfire?
valve to valve damage to both, valve to piston will damage to both, all the rings intact?
It's a Tman cam?
Yes T-Man 660PS-2
Yes both bolts on that side of the Rocker plate loosened up as well as the 2 corner bolts for the lower rocker housing.
Yes that is the valve that had the damage but never stuck, it still moves very freely in the guide.
No all 4 bolts were loose on that side of the head.
I definitely believe the loosening of the bolts contributed to the current issue, it did lift..
No i didn't have any backfires..
I never pulled the pistons because I initially didn't see anything that indicated any P/V contact. Also after i replace the cylinder head with my Stage II heads my leak down test went from 38% to 6%. I believe my initial ring gap was .026" top and .022" 2nd... So i don't believe there is any damage to the rings..
Again I'm pretty certain that where the valve is bent could only be caused by either V-V or V-P.. But I could not find any witness marks to confirm which might have happened.
In the following link that I posted about the heads and valve clearance you can see that the rocker geometry was way out, I still believe that this was the issue with the bolts loosening up causing the whole situation.
Valve To Piston Clearance... - Page 3 - Harley Davidson Forums (hdforums.com)
This
