Polished stainless bolts
Old Aug 30, 2007 | 10:10 PM
cpa55's Avatar
cpa55
Default Polished stainless bolts
I have a black 2007 Street Bob and I wanted to see if anyone has put the polished stainless bolts on their engine. I am curious how they lookagainst the black engine. I have found the polished bolt with the knurl left on and show polished bolts with the knurl ground off. If anyone has either, please let me know how you like them.
Thanks,
David
Old Aug 30, 2007 | 10:11 PM
MisterB's Avatar
MisterB
Default RE: Polished stainless bolts
ORIGINAL: cpa55
Thanks,
David
I just got done installing chrome ones, but there are some guys on one of my threads that did the ones you are talking about. Check out a thread in the Softail section, titled "Night Train ****".
Old Aug 30, 2007 | 10:37 PM
cpa55's Avatar
cpa55
Thanks for the info MisterB.
Old Aug 31, 2007 | 04:20 PM
fullauto4u's Avatar
fullauto4u
Stage III
The polished stainless bolts are the only way to go. Chrome ones will rust inside the hex, etc. I have used the Diamond Engineering smooth polished bolts and they have held up for years with NO maintence.
Old Aug 31, 2007 | 09:39 PM
Imjonesy's Avatar
Imjonesy
Let me ask you this, did you have to replace the gasket set, or did you just pull and replaceone boltat a time in a staggered set?
Imjones
Old Sep 1, 2007 | 12:04 PM
JRK5892's Avatar
JRK5892
I replaced all the gaskets... came out awesom!!! here are the head bolts i polished against my black heads... looks SICK WITH IT!
[IMG]local://upfiles/26534/8233DD56E1D848DBBCCB903BD0BC530F.jpg[/IMG]
Old Sep 1, 2007 | 07:51 PM
tattoofreaksb's Avatar
tattoofreaksb
Looks good. I'm going with the Diamond Engineering 12 point set up on mine. Kinda pricey but I think it's well worth it.
Old Sep 2, 2007 | 06:06 PM
TOMMAY's Avatar
TOMMAY
I've replaced or capped most every nut and bolt on my bike, mostly with chrome smooth sided allen head bolts. The look would be about the same as polished stainless. The above poster is correct about the rust. About half the upward facing bolts rusted on the inside of the bolt head. I'm told that a dab of clear fingernail polish will fix that problem. I just used the small polished caps that plug into the openings to cover the openings. Looks pretty good. I just replaced the bolts one at a time and have had no problem with leakage except on the outer primary after about ten thousand miles and it stopped after I snugged up the lower bolts.
This pic will give you some idea of what it will look like.
Good Luck
Tom
timberwolfz28
Nov 27, 2013 07:48 PM
Rolyn
May 19, 2009 09:11 AM
cpa55
Detailing
Jan 1, 2008 12:49 PM
cpa55
Aug 19, 2007 11:14 AM
cwsharp
Exhaust System Topics
Aug 11, 2006 10:08 AM
