Compensator Issues 03 FXDWG
Old Aug 3, 2024 | 08:26 PM
  #31
EppsHD's Avatar
EppsHD
Originally Posted by Jackie Paper
Did you by chance dry fit it to eyeball alignment of sprockets. Just stacked there like that, that's pretty amazing it ended up with the sprockets closer then .030 or a 1/32".
It that OEM parts?
Glad it sounds good. If it's out of alignment, you will hear a ticking in slow 180 turns.
It's hard to visualize how your old components face wear amounts to but if alignment looked good at assembly, I imagine that may be your .05 that put it back in alignment.
Dry fitted the new one & yes it was within specs. The old compensator wasn't out of alignment. It was showing signs of wear on the inside of the Sprocket and slide cam.
Old Aug 3, 2024 | 08:31 PM
  #32
Jackie Paper's Avatar
Jackie Paper
Community Influencer
But wouldn't that have let the sprocket move inward. That face wear on the alternator rotor definitely is part of the positioning of the sprocket for alignment.
Old Aug 3, 2024 | 08:51 PM
  #33
EppsHD's Avatar
EppsHD
There was no face wear on the outside of alternator cover. That was inside.What you seen is how the stock cover is on the inside. No wear on the outside
Gappy
Shovelhead
Oct 5, 2020 08:12 PM
cerelious
48
Jun 24, 2019 07:10 PM
MURPHCC1
59
Aug 17, 2017 05:14 PM
WS6 Formula
Apr 30, 2017 12:11 AM
JustOneMoreKick
Shovelhead
Aug 19, 2016 02:26 PM
