Add Tach
Old Nov 2, 2024 | 10:18 PM
scooper321's Avatar
scooper321
Originally Posted by 1madmouse
The problem I am having is no wiring plug in and no info about if these tachometers will work on my ride.The first I found was a kit to add a tachometer, but not sure if it will work or has all the parts. I don't really want a wiring nightmare. I know many will say easy to wire, but I have heard some people having problems with they work, maybe half speed . Aftermarkets don't have kits that I have found yet and I want to match my existing speedometer. So bigger headache than I wanted for now, I'll just wait a bit. I do appreciate all the input from all of you here at the best forum for our rides. Thanks.
most of the tax will have three wires: power, ground, speed. The speed will go to the pink wire in the harness under your console. If it is not reading accurately then it’s likely someone has upgraded your ignition. In that case, you will have to connect to a different wire. Just find the documentation online for your ignition and it will tell you exactly what to connect. In terms of wiring difficulty, this is not hard at all. The biggest challenge would be if you had to run a new wire from the ignition up to the tach. And even that’s not difficult.
Old Nov 3, 2024 | 05:45 AM
FXD2003Rider's Avatar
FXD2003Rider
Administrator Emeritus
Originally Posted by FXD2003Rider
@1madmouse Here's a link to the H-D Instruction Sheet for the Tachometer kit.
The tachometer's p/n is 67042-99. If you search Ebay for this p/n you'll find multiple sellers...
The above p/n is for the tach with a chrome trim.
P/n 68941-99 has a black trim and wil fit as well.
Some are listed at Ebay for under and around US 100
Old Nov 3, 2024 | 06:51 AM
Hey Man's Avatar
Hey Man
I have one on my Heritage Classic. It's a piece of cake. One tach, one bracket and two wires that are already on the tach. 1/2 hour install.
Old Nov 3, 2024 | 10:16 AM
1madmouse's Avatar
1madmouse
Thanks again I am looking at the double set-up Speedo and tach side by side should be plug and play, but not finding the complete kit with wiring and Tachometer. I have found quite a few Tachs. I don't want to cut or splice wiring if I don't have to. I was warned kits are probably non existent or really hard to find. I am trying to decide if I really need to add the Tach. Its going to be polished/chrome lower fork tubes or Tach. I'll figure it out
Old Nov 3, 2024 | 07:36 PM
scooper321's Avatar
scooper321
you’re looking to add an electronic gauge to your older bike. You have to. Come to grips with it. Buy a decent set of wire cutters and a good stripper. Then get a heat gun and these
https://a.co/d/aFZ0oDw
It’s not as scary as you’re envisioning it to be.
Old Nov 6, 2024 | 05:24 PM
Stretchman's Avatar
Stretchman
https://www.denniskirk.com/drag-spec...prd/409054.sku
Still, 140 plus the cost of the gauge, and the mounting kit.
Maybe try Koso North America and see what they have available. At least the gauge would be new.
Old Nov 6, 2024 | 08:33 PM
slewfoot1956's Avatar
slewfoot1956
I removed mine to clean up the handlebar area and had it installed on the forks. I can see it just fine. I might have a tach for the other side.
Old Nov 6, 2024 | 11:26 PM
1madmouse's Avatar
1madmouse
Polished Fork lower sliders won this round. I have the tools and info to do the gauge add, but no time right now. I have seen plug and play wiring just have to find it again.
Mark Winchester
Nov 14, 2020 10:14 PM
Alaus24
Dec 31, 2019 12:19 PM
FXDL32966
Jun 26, 2017 04:17 PM
Kevin714
Mar 21, 2013 12:22 AM
blink1968
Jul 17, 2011 01:08 AM
