Engine noise
Old Oct 30, 2024 | 03:21 PM
  #31
Shadowjag's Avatar
Shadowjag
I replaced 1 shoe with Twin Power. Bought the other from...LOL. DK. Oh well. I'll be monitoring MUCH closer now.
Old Oct 31, 2024 | 09:38 AM
  #32
hattitude's Avatar
hattitude
FWIW.....
Dennis Kirk shows the Twin Power tensioners, but only has one of them in stock. When I checked about 5 years ago, Twin Power DID use Cyco tensioner pads in these replacements... But a lot can change in 5 years
Dennis Kirk also sells replacements from V-Factor, which based on my personal experience, don't look like Cyco pads...
V-Factor tensioners
V-Factor tensioners
Old Oct 31, 2024 | 09:58 AM
  #33
brakeless's Avatar
brakeless
Wouldn't it be great if some aftermarket company designed and sold a better "mousetrap"? You know a replacement shoe assy that has more controlled pressure? I know, not too many are interested in that type of replacement. The better fix is to go to the post '06 hydraulic setup or even gear drive. But at one point in time I bet that would have been big.
Old Oct 31, 2024 | 11:55 AM
  #34
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Originally Posted by Jackie Paper
The only way out of the cam galley is thru the crank roller bearing. Fine stuff small enough to float would have to go thru that bearing ,
So you are saying that for oil that accumulates in the cam chest, it must flood the camchest up to the engine roller bearing and find its way out?
Am I missing something here?
What about the scavenge tube on the pump, inside the cam galley?
Old Oct 31, 2024 | 12:23 PM
  #35
Jackie Paper's Avatar
Jackie Paper
Community Influencer
You are correct. Thank you.
I have only been into 3. And as much oil dumps, I assumed that was were oil went out from the pressure relief spring.
My bad and I have updated my reference.
Old Oct 31, 2024 | 06:28 PM
  #36
skills's Avatar
skills
Boy I'm glad I went with gears both times I upgraded cams. Sorry for all the pain you're dealing with.
Old Oct 31, 2024 | 08:49 PM
  #37
Shadowjag's Avatar
Shadowjag
I'm putting everything back together now. Cleaned all that I could. Cam plate is good. Passages in and out of the cam housing are clear. Pulled the pressure pin, spring and checked. Even flushed the oil pan with more oil. Only place I can think that might cause issues later is the bottom of the engine. Small pieces circulating everywhere. Thoughts?
Old Oct 31, 2024 | 09:55 PM
  #38
brakeless's Avatar
brakeless
Some have pulled the plug in the block and flushed it several times.
Old Oct 31, 2024 | 10:49 PM
  #39
scooper321's Avatar
scooper321
Thats what I was thinking. Couldn’t you get some cheap oil, pull the drain plug and just put the oil into the tank, letting it drain right out? Maybe also inserting oil down the dip stock tube, letting it run out too. Once it’s all drained out, put good oil in and run it. You might want another change after running it just a bit, in case anything that was still lying in the bottom of the engine got stirred up and is now suspended in the oil. After that, you’ve prob done what you can, short of disassembling the whole engine.
Old Oct 31, 2024 | 10:56 PM
  #40
brakeless's Avatar
brakeless
I don't think oil will give the best effect. I've heard of using kerosene and even pressurizing it. Some will say you will never get all the small fragments out of the many nooks and crannies. Still, I think I'd be tempted to do whatever I could in that situation where there may be metal fragments.
